Originally Posted by NullPointer
Sorry I'm not that good with cars. What do you mean by "play in the wheels"? If there is play in the wheels, what would that indicate?
Thanks so much for your help.
jack it up, but a hand on the top and one on the bottom and shake the wheel, if its stiff and has no movement then youre good, if there is movement you need a ball joint, now do the same thing but side to side, if there is no play then youre good but if there is then youll need a tie rod
