Go Back   Honda Forum / Acura Forum - SuperHonda.com > Acura - Vehicles > TL Forum
Old 05-18-2006, 10:54 AM   #1 (permalink)
Car: 2001 Prelude base
aznswtlkr is a jewel in the roughaznswtlkr is a jewel in the roughaznswtlkr is a jewel in the rough
SRS light on 02TL-S
hey I got an 02 TL-S and recently the SRS light came on. I thought it was the fuse but when i checked the fuse (7.5amp), it was fine. The light still lit and I'm not sure if the problem requires dealership service. Would unplugging the battery and reset the ecu do anything to it? Let me know guys.
Mr.Minh
aznswtlkr is offline
Old 05-21-2006, 08:56 PM   #2 (permalink)
Accord2000LX is an unknown quantity at this point
Did you do something relate to electrical or unplug the battery? SRS light on is indication of passenger airbag is disable which under accident, it won't deploy! So if you did not do anything to the car at all and suddently the SRS light on, bring to the dealer to check out. IF under warranty, it will be fix for free. Better safe than sorry.
However, if the SRS light on due to the result of disconnected the battery or short circuit due to install electrical equipments, then there's an easy fix:
Here are the instructions for resetting the SRS light. (instructions copied from DareIL)
1. there is a Yellow 2 Pin connector with 2 greens wires in it.
2. It is under dash left of steering wheel as the driver sits.
3. smaller yellow block is the right one and is located one inch above another bigger yellow wire block which has a spring loaded connector.
Unplug the connector then Bend the paper clip to a U-shape and stick the paperclip in the 2 holes..
turn the car on, wait for the SRS light to go off, yank the paperclip out.
It'll light up again, shove the paperclip back in...
then it'll turn off. Yank it out. It'll then blink twice to tell you it's reset.
Don't worry about the timings...just do it as soon as you see the light change (and do it quick).
I cut a thin paperclip to about 2cm long, then bent it with needle nosed pliars so it looked like a staple. Then I just used the needle nosed pliars to push it in and out of the plug. Just be careful to shove it into the right side of the plug...the one side of the hole doesn't contact the metal.
"Huu duyen thien ly nang tuong ngo,
Vo duyen doi dien bat tuong phung."
Accord2000LX is offline
Old 06-01-2006, 08:30 PM   #3 (permalink)
ACURATECH is an unknown quantity at this point
i would take it to the dealer. most likely it is a passenger seat opds code or seat belt buckle code stored . honda has a lifetime seat belt warranty and they just extended the opds unit warranty. it is probably an opds code 15-1,15-2,or 15-3 code
ACURATECH is offline
Old 09-27-2006, 06:21 PM   #4 (permalink)
To busy for SHO
Hondaguy1980's Avatar
Car: 1996 Honda Accord EX, 2002 Acura TL 3.2 Type S, 2007 Honda Civic EX, Nav
Mods: Nothing special, I like my car how it is.
Hondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud ofHondaguy1980 has much to be proud of
A couple months ago I got notified of a warrenty extension for that problem. I had the same thing happen, and I took it in, and everything was fine.
I also have heard of people using a paper clip to jump somthing......but I would not recommend that because it could cost you your life.
Hondaguy1980 is offline
Old 12-30-2006, 10:26 AM   #5 (permalink)
sihatch6166's Avatar
Mods: 00 civic w/ b16a. I/H/E
sihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputationsihatch6166 Among Gods/Goddesses in reputation
this method really works, just did it to my brothers 02 TL-s a week ago
97 Civic Red- SOLD
96 Teg Black- SOLD
00 Civic Silver - SOLD
00 Civic Black -SOLD
00 Civic White - SOLD!!
00 Civic Black #2 SOLD
00 Civic Silver # SOLD
00 Teggy Gsr- current
sihatch6166 is offline
Old 09-04-2008, 09:38 PM   #6 (permalink)
03TLdriver is on a distinguished road
i can comfirm that this method definatily works because i did it to my car last night. it worked just like they said but you have to do it fast as instructed.
03TLdriver is offline
