12-16-2006, 12:43 PM
#1 (permalink)
Super Moderator
Car: 01 MR-St & 08 M3
Final Fantasy XII & PS3?
when i start the game it says i need a dual shock controller or something. do i need to use a USB to ps2 controller thing?
Natural Progression...
Nulla tenaci invia est via.
For the tenacious, no road is impassable. Team SHO: 54075 - Folding for a cure
folding@home
12-16-2006, 05:10 PM
#2 (permalink)
Mods: STOCK
i wonder if they make one...i got one for my ddr pads its a USB to PS2 connector. dont know if i need drivers somehow if i tried to hook it up to my ps3.
is XII for ps3 or ps2?
12-16-2006, 10:01 PM
#3 (permalink)
Super Moderator
its for ps2....but i got it to work.
folding@home
12-17-2006, 01:31 AM
#4 (permalink)
Mods: STOCK
can you save new game data for ps2 games on ur HD?
12-17-2006, 02:23 AM
#5 (permalink)
Super Moderator
yeah. you have to make a virtual ps2 memory card and load it into a virtual slot.
folding@home
12-17-2006, 04:45 AM
#6 (permalink)
Mods: STOCK
i just figured it out..it has 2 game slots so i can make one for the PS1 and the PS2.
its a shame i lose all my "real" memory card data though.
12-17-2006, 09:45 PM
#7 (permalink)
Dark Wind
Car: 1993 Honda Prelude Si (H22a Swap)
Mods: JDM H22a Swap, Greddy SS Header, Greddy SP Cat Back, Car Sound highflow Cat, Skunk2 Cam gears (tuned), Light weight Flywheel, AEM CAI and Short Ram (I switch for different things). ON THE WAY: JUN Valve Train, Jun High Comp Pistons and JUN Flywheel
Do you have all your updates?
Once you update, it should auto switch to Analog mode, if it doesn't, here's what you can do.
Just start the game, then hold the "PS" button, and switch it manually to analog mode. Problem solved and the game will play fine
Enjoy.
12-17-2006, 10:15 PM
#8 (permalink)
Mods: STOCK
Enjoy.
the controllers seem cheap...i dont like it
12-18-2006, 12:11 AM
#9 (permalink)
Super Moderator
Enjoy.
yeah i figured it out a while ago already.
folding@home
12-18-2006, 12:22 AM
#10 (permalink)
Mods: STOCK
do ps2 games play any different on the ps3? i havent pulled my ps2 games out to play it yet.
12-18-2006, 09:12 AM
#11 (permalink)
Super Moderator
for me, not really. my brother (who has better eyes than me) says that it looks more blurry  i'm running it through the hdmi cable though. so maybe the hdmi doesn't do well w/ standard definition?
folding@home
12-18-2006, 10:39 AM
#12 (permalink)
Dark Wind
PS2 games over HDMI connectors look "worse" because of what needs to be done in order to ensure full compatibility.
Basically, not all TV's accept 480i over HDMI, so what Sony does is take the 480i signal, and "double" the lines, basically creating a 480p signal. This "upscaling" looks terrible, simply because instead of de-interlacing the signal, Sony simply doubled every line of resolution for every interlaced half of a frame...so it looks terribly "blurry" and "jagged".
Over Composite, S-Video, and occasionally even Component looks significantly better. Games that use Progresssive scan get rid of this problem, and the problem is not consistent with all games.
Nations - I like the controller, it's light, and easy to use, which is important IMO for a wireless controller. Especially if you're going to be moving it around (try motorstorm for instance). If I'm going to play games for long periods of time that need motion, lighter is better.
12-18-2006, 11:14 AM
#13 (permalink)
Super Moderator
can you have both the hdmi and regular analog outputs connected at the same time? then just pick which input to use on the TV?
folding@home
12-18-2006, 12:28 PM
#14 (permalink)
Dark Wind
You'll have to switch it on the PS3 (i.e. go into your display options and switch from HDMI to component or composite). But, yes, you can.
