Car: 93 del sol si/04 element exs,76rm370,72ke250,kz1425,18'boat
Mods: sol-zex cam&gear,cp cai,dc sports header,spoon cat,pilot exh,apexi flywheel,clutch,diz,coil,plugs,wires,gold line springs,f/r strut brace&lower tie bars. element-exs,real time awd,side air bags,fog lamps,top rack,rear fin,tow pkg,sun roof,11"swivel dvd,playstation2,240watt premium sound system w/sub,mp3 input,rear pwr receptacle,tint.
element tranny service
i have the 04 element and the automatic trans fluid is due for a change. does n e 1 know if it is a drain and fill or pan gasket and filter change? thanx for n e or all info.
1993 del sol si
2004 element exs
sol-zex cam&gear,port/polish,cp cai,dc header,spoon cat,pilot exh,apexi flywheel/clutch,diz,coil,ecu,fuel pump,ngk's,8mm wires,gold line springs,f/r up strut brace&f/r lower tie bars,silver dash accents,euro police air horn,german front plate. element-exs,real time awd,side air bags,fog lamps,top rack,rear fin,tow pkg,sun roof,11"swivel dvd,playstation2,240watt premium sound system w/sub,mp3 input,rear pwr receptacle,tint,german front plate.
n e 1 ?
1993 del sol si
2004 element exs
ok i found the info, pull the pan,change gasket, no filter with a fluid change. honda dealer here local does it for $53
1993 del sol si
2004 element exs
[b] All Hondas are drain and fill. You must use Genuine Honda transmission fluid, especially if it's an automatic. You cannot flush a Honda transmission, at least, not one I've ever serviced in the 15 years I've been working in the auto service business. Take care, Have Fun!
