» Sponsors
» Sponsors
Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Element Forum
Old 12-28-2008, 05:04 PM   #1 (permalink)
sisco134 is on a distinguished road
programing a door remote
Does anyone no how to program a door remote for a 06 Honda Element bought the car it was missing .
Thanks
sisco134 is offline
Old 01-15-2009, 12:16 PM   #2 (permalink)
Dark Wind
MrsTransparent's Avatar
Car: 1991 CRX Si - 2006 Element
Mods: Hopes and Dreams
MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?MrsTransparent you're still here?
Keyless entry? If you have the remotes:
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by “II” on the ignition bezel so the dash lights come on, then within 5 seconds press the “Lock” button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by “I” on the ignition bezel – dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) – each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to “ON”, press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will “pop”.
If you don't have the remotes and are installing the kit click here.
MrsTransparent is offline
Old 07-26-2009, 07:06 AM   #3 (permalink)
Car: 2005 Civic
Mods: Intake: K&N Headers: DC Sports 421 Exhaust: 1.75 Customized Pipings; Spoon Street Stype Muffler
francis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these partsfrancis09 is infamous around these parts
Nice reply, thanks for sharing. If your having trouble go to your dealer they can help you with that.
francis09 is offline
