Originally Posted by honda_37
have a d15b block with d16 head my timing belt doesnt seem to tighten enough im using a d16 belt for 92-95?? is that wrong? its making this loud slapping noise when the rpms are high, can someone please help me out here??
Slapping belt noise = Imminent engine destruction if it jumps a tooth.
procedure:
Loosen the tensioner bolt 1/2 a turn rotate the crank anti clock wise until the camshaft is 3 teeth past TDC then tighten the tensioner to 44 nm (32 lb ft)
Did you do it this way?
If no better maybe try a new tensioner+spring. . .
Other than that find a shorter belt with the same teeth distance spacing.
Because learning is fun
Twin engine Honda go kart-
Sold
1985 Ninja 600R-
Sold
2001 GSXR 600-
Sold
1994 R33 Skyline GTS Turbo-
Sold
1975 Suzuki TS 250-
Sold
All toys sold to make room for-
2010 Baby -
Pre Ordered for Aug/Sep.
