Accord 2004 Automatic Transmission Oil - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 05-27-2007, 12:00 AM   #1 (permalink)
oziking is an unknown quantity at this point
I am using 6cyl Accord 2004 with automatic transmission. Dealer told me that i must change automatic transmission oil after 80,000KM.
People says that usually changing the automatic transmission oil destroys the gearbox etc and ends up in lots of problems. Friends says better dont touch it unless its dirty.
Please help me on that.
oziking is offline
Old 05-27-2007, 10:07 AM   #2 (permalink)
mattlisa is an unknown quantity at this point
I had an 03 ex v6 that should have been changed well before that. The original honda trans oil is all that can be used. It's 4something a quart, but it's cheap insurance against premature failure. The trans has a drain plug and crush washer. refill with a little over 3 quarts with the atf z1 honda oil. I'm doing it every 20,000.
mattlisa is offline
Old 05-29-2007, 08:42 AM   #3 (permalink)
thanks a lot for your answer i will get it changed soon.
Really appreciated
oziking is offline
Old 05-29-2007, 11:36 AM   #4 (permalink)
Car: Honda Accord V6
Mods: AEM Short Ram, O'reilly Alternator, Belts, Brake Pads, and Rotors
texasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these parts
i changed mine at 75k at the dealership. i'm just going with the normal maintanence schedule that's listed in the manual.
the only thing that i do different is the oil change interval. i change with mobil 1 every 15-20k miles, ends up being about 1 change a year.
running strong and smooth since day 1. got 139,000 miles so far.
texasKA is offline
Old 07-16-2007, 09:24 AM   #5 (permalink)
cpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhilecpcritter Needs to go outside once in awhile
Another Trans oil opinion
I do my own maintenance and was told by the dealer to do a partial fluid change on my 2001 Ody every 15K miles. The procedure is so easy for a partial change and fluid is so cheap that I do the same change interval for my accord. This is very cheap maintenance and the car is getting enough fresh additives to minimize potential future issues.
cpcritter is offline
Old 07-17-2007, 07:52 PM   #6 (permalink)
HondatechAV6's Avatar
Car: 2011 Accord EX
any time i see these 15k+ oil change intervals i cringe.
even 5k+...icky.
I'm just a nice guy.
HondatechAV6 is offline
Old 07-18-2007, 03:17 AM   #7 (permalink)
Cringe Factor
Are you cringing at a 15K motor oil change or a 15K trans fluid partial change. I have always been of the belief that changing the engine oil with quality oil and a quality filter is the lowest cost most beneficial thing that can be done for your car. I do my too often at 3k to 4K, my work pays for it though I do the labor. With Honda making the trans fluid change as easy as it is I am all over the 15K interval for that. I hate the idea of multi thousand dollar transmission job that could have been prevented. Is my thinking correct?
Old 01-19-2008, 12:38 AM   #8 (permalink)
thanks alot everyone
oziking is offline
Old 01-25-2008, 09:39 AM   #9 (permalink)
Car: 2003 Honda Accord EX V6 Coupe
Mods: I/E and others
SatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a lifeSatinsilverAV6 You need a life
The transmission fluid should be changed every 30,000 miles. Do not flush!
Conventional oil should never go over 3,000 miles. I change my oil every 5,000 miles but I use Mobil 1 synthetic and a fram tough guard filter or a high mileage Fram filter for the extended period. Using frams regular oil filter with synthetic wont give you 5000 mile protection since the filter is not designed to last 5,000 miles and still work efficiantly.
-Injen CAI
-Magnaflow Cat-back
-Evolution HID Kit
-TSX 17" Wheels
-Hyper Ground System
-Neuspeed Strut Bar
SatinsilverAV6 is offline
