Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Accord Forum > Accord - V6
Old 03-24-2008, 11:02 PM   #16 (permalink)
Baris Sener is on a distinguished road
As long as I am able to drive the car, I do not mind the hesitation. I do not need a nice car right now. I am trying to graduate from college. I just need a box on wheels mine has 123k right now. And I am a delivery guy too
Baris Sener is offline
Old 03-25-2008, 04:14 PM   #17 (permalink)
ballahs-crew's Avatar
Car: 98 Accord V6
Mods: Rice... pssh SIKE!!!!
ballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these partsballahs-crew is infamous around these parts
see thats the spirit keep up the good work
Haynes = Bible
ballahs-crew is offline
Old 03-25-2008, 04:26 PM   #18 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
tienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapytienlude needs rep therapy
i got a friend with this same exact problem, but so far im not readin a solution here....just a bunch of pple agreein to the same problem...
well, ill see, imo, i think all coils might need replacing..how much do they go for..and ill give that hot soak a thought..
'92 with an H22J.
tienlude is offline
Old 03-25-2008, 06:14 PM   #19 (permalink)
Car: 1991 Civic Std Hatch
Mods: 400+HP D16Z6
Chiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problemChiovnidca has a Rep problem
Originally Posted by texasKA View Post
also, they told you the Bosch plugs were bad? freaking Bull Sh* t, i been running the Bosch plugs since 100k miles, and just replaced them b/c i was already replacing the coils.
the brand of plugs has nothing to do with the problem.
BOSCH PLUGS F-ING SUCK IN A HONDA. DO NOT RUN THEM.
95% of the cars that come into the shop with a no start or a running problem that is caused by bad spark plugs have Bosch plugs in em. And I know it's not just my experience.
Replacing your plugs is what cured your missfire, not the coil packs. 6 coil packs going bad at once??? LOL
1991 Civic Std hatch + D16Z6 + Turbo = 11.2@121
My project car, lots of pics.
Chiovnidca is offline
Old 03-25-2008, 06:22 PM   #20 (permalink)
Mods: 400+HP D16Z6
I doubt very much there is a problem with all the coil packs. They rarely go bad, and usually just one at a time.
Dont just throw parts at it, that gets expensive fast. A scantool with a data list capability makes diagnosing misfires on em fairly easy.
Old 03-25-2008, 06:32 PM   #21 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
Originally Posted by Chiovnidca View Post
..... 6 coil packs going bad at once??? LOL
so true....
'92 with an H22J.
tienlude is offline
Old 03-25-2008, 06:48 PM   #22 (permalink)
So are you suggesting that we should change our spark plugs with a brand other than bosch. and our problem will be solved?
Old 03-25-2008, 07:11 PM   #23 (permalink)
Car: 98 Accord V6
yeah bosch is bad just run oem - NGK or Denso.
Haynes = Bible
Old 03-25-2008, 07:40 PM   #24 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
the way u write it seems condescending.
basic honda mainenance....u never put n e thing other than ngk denso...it might fix it, it might not...but thats what is supposed to go in there.
'92 with an H22J.
tienlude is offline
Old 03-25-2008, 07:56 PM   #25 (permalink)
Mods: 400+HP D16Z6
Just pointing out a possible cause, something the average guy working on his car may not know. I've looked at dozens of hondas that have been towed in to the shop that wouldn't start to find bosch plugs to be the cause. Then when you call the customer and tell them they need new plugs they gripe that they just tuned the car up 100 or 1000 or 10,000 miles ago. Some of em get downright pissed and think we're trying to rip em off or something. A nice fresh set of ngks and they fire right up.
edit> More often they just cause a misfire or running problem.
Old 03-26-2008, 08:44 PM   #26 (permalink)
Car: Honda Accord V6
Mods: AEM Short Ram, O'reilly Alternator, Belts, Brake Pads, and Rotors
texasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these partstexasKA is infamous around these parts
ok, just finished changing the fuel filter, sensor, and pump.
the car runs smoother and more responsive when i press the gas pedal lightly. when i press the gas pedal half way down and/or all the way to the floor, the car hesitates with very poor response and the car does not speed up as it should. CEL will start blinking (and stay on if i continue to press the gas pedal). CEL will eventually turn off and go away if i stop pressing the gas and/or press the gas pedal lightly.
when the CEL stays on, i get codes P0300, P0303, 0304, and 0305, and P1399
WTF is wrong with the car?
texasKA is offline
Old 03-26-2008, 09:39 PM   #27 (permalink)
Originally Posted by abduktid View Post
I payed the $100 to have my car diagnosed about 2 weeks ago and Honda said the catalytic converter and the EGR valve had to be replaced. They quoted me at $2150 so I just had someone else do the repairs for $600.
so did the new CAT and EGR valve replacement solve the problem?
the Random Technologies high-flow cat costs $230 @ Stillen for the 98-02 3.0 V6
texasKA is offline
Old 03-27-2008, 01:31 AM   #28 (permalink)
Dark Wind
tienlude's Avatar
Car: 92 prelude
Mods: jdm h22
whats codes are those? is the timing good?
'92 with an H22J.
tienlude is offline
Old 03-27-2008, 02:16 AM   #29 (permalink)
tatanano_lover's Avatar
Car: 2010 Tata Nano Concept
Mods: Skyline engine, 6 disc cd changer, A/C, Fuzzy dice
tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover tatanano_lover
I like it in the butt
Skyline RB26 engine, 6 disc cd changer, A/C,
Fuzzy dice, Plasmas in both visors
tatanano_lover is offline
Old 03-27-2008, 04:19 AM   #30 (permalink)
clayton's Avatar
Mods: yes, please.
Originally Posted by tatanano_lover View Post
You need to sell that piece of shit and but a Tata Nano. It's the most reliable car ever made and you won't have to replace coil packs bcuz it has points.
[IMG]
you need to piss off already.
