» Sponsors
» Sponsors
Old 02-18-2003, 02:29 AM   #1 (permalink)
GunMetal Member
Car: 2003 Civic Si
Mods: STOCK....HAHA
91CivicSiR is an unknown quantity at this point
2002 Civic Si VTEC Engagement
Does anyone know how VTEC sounds on the 2002 Civic Si with an Aftermarket Exhaust is installed? Does it sound ANYTHING like the VTEC Engagement on a B-Series motor? I just bought a 2002 Civic Si (paid cash $17500) and the exhaust is TOO quiet and I was just wondering if anyone has done this or heard one with an Aftermarket Exhaust......OH Yea and AFTER 500 miles the car pulls ALOT harder.....I think it has something to do with the ECU not letting the motor do its full thing until its broken in.
Now I am ProspeedCTR
91CivicSiR is offline
Old 02-18-2003, 03:12 AM   #2 (permalink)
AREITU is an unknown quantity at this point
The new Civic Si has "half-ass" VTEC which is only on the intake side. It uses the base RSX engine. There's VTEC, you barely hear it, but it's only on the intake side.
AREITU is offline
Old 02-18-2003, 08:50 AM   #3 (permalink)
Car: 2002 Civic Si HB
Mods: Injen CAI
2002Si is an unknown quantity at this point
huh???????? Well it doesn't hit as hard but spoon and aj racing have done a head swap from the RSX and it worked so the lil "half-ass" VTEC can be cured soon
well to tell you the truth it sounds a lot better than a B series because it has a deep throaty sound, and with i/h/e it sounds even better.
2002 Civic Si HB
Injen CAI
You gotta get one!!!
Got i-VTEC????????????????
2002Si is offline
Old 02-18-2003, 08:52 AM   #4 (permalink)
Mods: Injen CAI
Re: 2002 Civic Si VTEC Engagement
The car will open up as you get up in the miles, you need to go to
and become a member!!!
2002 Civic Si HB
Injen CAI
2002Si is offline
Old 02-18-2003, 11:02 PM   #5 (permalink)
Car: 2000 civic ex
civicman02 is an unknown quantity at this point
i can't remember where i got the info. but it was a good sight talking about the dif in the rsx type-s motor and the civic si motor. i don't remember exactly but the si's vtec kicked in really early like 2700 i beleive but don't quote me on that. but i know for sure it was less than 3000
hope that helped
peace
civicman02 is offline
Old 02-19-2003, 08:35 AM   #6 (permalink)
Mods: Injen CAI
Well you can find out just about anything that you want to know about the Si on
2002 Civic Si HB
Injen CAI
2002Si is offline
Old 02-20-2003, 04:13 AM   #7 (permalink)
Car: 2002 Honda Civic Si Hatch
T.Slick has a little shameless behaviour in the past
Thumbs up
I drive a 2002 EPhatch. I can't compare the sound of the exhaust to any other Honda--this is my first. But I do have a Thermal exhaust. Very deep throaty sound. I also thought the car was a bit quiet. The cai helped as well. And the ephatch website is totally tits. Everything you want to know you'll find it there.
My Turbo'd EP
T.Slick is offline
Old 02-20-2003, 05:27 AM   #8 (permalink)
Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!Targa250R Um, 1 million? Damn!
No. The K20A3 does not have a standard DOHC VTEC valvetrain as we know it from the B-series engines - the K20A3 should actually be called a "DOHC i-VTEC-E" engine, because it uses a VTEC-E cam setup. The K20A2 is the "real" DOHC i-VTEC engine, utilizing the standard DOHC VTEC cam setup we're all familiar with. To help you understand the differences between the K20A2 and K20A3 engines, I've included the following information from a post I made elsewhere:
Allow me to evaluate. Let's start out by defining some terms:
VTEC - Variable valve Timing and lift Electronic Control. At low RPM, a VTEC engine uses a normal cam profile to retain a smooth idle, good fuel economy, and good low-end power delivery. The VTEC mechanism engages a high-lift, long-duration "race" cam profile at a set RPM value (i.e., ~5500RPM on the B16A) to increase high-end power delivery.
VTEC-E - Variable valve Timing and lift Electronic Control for Efficiency. This system isn't really VTEC as we know it. At low RPM, the VTEC-E mechanism effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At a set RPM value (i.e., ~2500RPM in the D16Y5), the VTEC-E mechanism engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. Note: in a VTEC-E engine, there are no high-RPM performance cam profiles; this engine is supposed to be tuned for fuel economy, right?
VTC - Variable Timing Control. This is a mechanism attached to the end of the intake camshaft only which acts as a continuously variable cam gear - it automatically adjusts the overlap between the intake and exhaust cams, effectively allowing the engine to have the most ideal amount of valve overlap in all RPM ranges. VTC is active at all RPMs.
i-VTEC - intelligent Variable valve Timing and lift Electronic Control. This is a combination of both the VTEC and the VTC technologies - in other words, i-VTEC = VTEC + VTC. Currently, the only engines that use the i-VTEC system are the DOHC K-series engines.
Now this is where things get tricky - Honda uses the term "DOHC i-VTEC" for two different systems: The first system is used in the K20A2 engine of the RSX Type-S. The second system is used in the K20A3 engine of the Civic Si.
The First System (K20A2):
This system is pretty close to the older DOHC VTEC engines. At low RPM, the K20A2 uses a normal cam profile to retain a smooth idle, good fuel economy, and good low-end power delivery. At 5800RPM, its VTEC mechanism engages a high-lift, long-duration "race" cam profile to increase high-end power delivery. The only difference between this i-VTEC engine and the older VTEC engines is the addition of the VTC system. The intake camshaft has the automatic self-adjusting cam gear which continuously optimizes valve overlap for all RPM ranges.
Here we see an image of the intake cam lobes of the K20A2. Notice there are 3 lobes; the two side lobes are the low-RPM profiles, and the center lobe is the high-lift, long-duration profile which engages at 5800RPM. Basically the same setup as the old VTEC engines we are familiar with.
Now here we see the VTC mechanism - the gear on the end of the intake cam that adjusts valve timing (overlap) automatically on the fly.
This system is used in engines powering the JDM Honda Integra Type-R, Civic Type-R, Accord Euro-R, and the USDM Acura RSX Type-S and TSX.
The Second System (K20A3):
This system does not really conform to the "DOHC i-VTEC" nomenclature, as Honda would like us to believe. As I mentioned in my previous post, it actually should be called "i-VTEC-E," because it uses a VTEC-E mechanism rather than a standard VTEC mechanism. At low RPM, the VTEC-E system effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At 2200RPM, the VTEC-E system engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. There are no high-RPM performance cam profiles; this engine is tuned to balance fuel economy and power, rather than provide pure performance. On the intake cam, there is the VTC mechanism which basically is an automatic self-adjusting cam gear used to continuously optimize the valve overlap for all RPM ranges. This being a VTEC-E system - and not a true DOHC VTEC system - is the reason the K20A3 redlines at a measly 6800RPM, while the K20A2 is able to rev all the way to 7900RPM.
Here we see an image of the intake cam lobes of the K20A3. Notice there are only 2 lobes - there is a nearly round one used only for the low-RPM disabled intake valve, and then there is the regular lobe used by the other valve at low-RPM and by both valves at high-RPM:
This system is used in engines powering the USDM Acura RSX base, Honda Civic Si, Accord 4-cylinder, CRV, and Element.
Special note: The K20A3 engine used in the Acura RSX base has a slightly different intake manifold design from the K20A3 engine used in the Civic Si. The RSX engine uses a dual-stage manifold, similar in concept to the manifold of the B18C1 in the old Integra GSR. It uses long intake runners at low-RPM to retain low end power, and switches at 4700RPM to a set of shorter intake runners to enhance high-end torque. This accounts for the extra 9 ft-lb of torque in the RSX (141 ft-lb, vs. 132 ft-lb in the Civic Si).
Here is an image showing just how this dual-stage manifold works. On the bottom, you can see the low-RPM (long) runners are in use, and on the top, you can see the high-RPM (short) runners in use.
Myths:
1. The i-VTEC engine engages VTEC gradually, and not suddenly like in the old VTEC engines.
Wrong. The i-VTEC engine "engages VTEC" at a single set RPM, like always. Whoever started this rumor is a moron. Read the definitions above.
2. VTC engages at a set RPM.
Wrong. VTC is always activated. Read under "VTC" above.
3. The K20A3 engages VTEC at 5000+ RPM.
Wrong. Technically, there is no "VTEC" (as we think of it) in the K20A3 engine - it uses a VTEC-E technology, which engages at 2200RPM. Read under "The Second Sytem" above.
Sources of pictures and information (good reading material):
http://www.leecao.com/honda/vtec/index.html
http://www.hondata.com/techk20general.html
Here is a bigger shot of the two different heads internally (I found this at EPHatch.com):
http://home.comcast.net/~rwdouglas1/VTEC/a2-a3.jpg
More information on VTC:
http://www.honda.com.au/crv/cr-v+spo...ng+control.htm
http://asia.vtec.net/article/k20a
http://asia.vtec.net/article/ivtec
RC38 | RD7 | ED6 | ED9 | EM1 | EJ1
Matta Motors
- The Honda Car People
Targa250R is offline
Old 02-20-2003, 05:33 AM   #9 (permalink)
jmcn R is on a distinguished road
Thumbs up
wow, now thats pretty thorough info right there, damn!:eek:
lol, geuss u dont need to sign up at that other web board, although it couldnt hurt for the future
NATO- No Altezza Taillight Organization
Team Jamaica WRC
jmcn R is offline
Old 02-20-2003, 07:02 AM   #10 (permalink)
tech wrench
So Targa. . .Have you ever worked for Honda or are you just a junkie? Wow, that was more information than I needed. It really sounds like the K20A3 is such a puss. I am gearing as much of my money to engine mods as I can get. My problem is I know nothing about Hondas at all. Never to late to learn and thank the higher beings for leading me to this website. So many of the websites are all about bodykits, making your American Honda "look like a JDM-spec Honda". It doesn't seem that important to me. Its merely my opinion. I do have some interior and non-engine mods too. Point is, if I can get more power, I will take that first.
Anyway thanks Targa250R for the educational post.
My Turbo'd EP
T.Slick is offline
Old 02-20-2003, 03:43 PM   #11 (permalink)
Car: 04 Scion xB ThunderCloud
jkdmstyle is an unknown quantity at this point
i have a K&N drop filter in my Si, and that's all the sound i need for now...
...before i got my Si i used to have a 2000 DX coupe, non vtec obviously, i put on an exhaust on that thing and it was so loud that i was really annoyed by it
Since the 2002-03 Si i-Vtec k20c also incorporates Variable Timing Control (VTC), wouldn't the power band be so linear that VTEC engagement would be a lot less noticable?
2004 Scion xB - 5sp
2002 Civic Si (departed)
2000 Civic DX (departed)
jkdmstyle is offline
Old 02-20-2003, 03:49 PM   #12 (permalink)
it's true that our exhausts are quieter than aftermarket, but i find it to have a much deeper sound than any stock civic exhaust before. Sometimes i can just hear it resonate when i drive in a confined area, like a parking garage
2004 Scion xB - 5sp
Old 02-20-2003, 05:10 PM   #13 (permalink)
GunMetal Member
Car: 2003 Civic Si
Mods: STOCK....HAHA
Umm no....These motors are pretty strong when I punch it in first the tires break lose (about 5-10mph roll) and the Torque is pretty amazing for it to be stock and the gears are spaced out well......The only thing I don't like about the car is the rear suspention its too soft (STOCK) the ass end drops down alot at full throttle.
Old 02-21-2003, 08:17 AM   #14 (permalink)
ArtcbluRsx's Avatar
Car: 02 Acura Rsx Type-S
Mods: Injen sri,Tein SS-P, Spoon N1 Axle-back exhaust,17x7 5Zigen FN01R-c, CFR pulley, Spoon upper rear strut, Spoon lower tie bar, Spoon front upper strut, Tanabe X-brace, ITR shift knob, 22mm ITR rear sway, Mugen Rear upper strut,Toda Engine Kit soon =)
ArtcbluRsx is an unknown quantity at this point
Wait until you get Hondata for your car...0-60times improve by a second and most peeps on e p h a t c h are pulling low low 15's no problemo w/ it....a few in the high 14's...
Its no puss my friend..top end may be alright but I'm pretty sure he makes more torque at his low end than you at your top end...I know for a fact the K20a3 makes a lot more torque faster down low than my car (K20a2) and the mightly S2k(F20c).....
Toda Power, Tein , Spoon, JDM , Tanabe, 5Zigen , Injen
ArtcbluRsx is offline
Old 02-25-2003, 11:11 PM   #15 (permalink)
GunMetal Member
Car: 2003 Civic Si
Mods: STOCK....HAHA
YEA!!!
