Mods: Eibach Pro Kit Plus, AEM short ram intake, Kuhmo all season/high perf tires, OZ 16" rims,PIAA bulbs, OEM Fogs, perf AEM pads, matching blue G2 caliper paint, brand new factory B16A2, all paint & body work repaired to 100% stock
Exhaust help- high flow cat- headers & wraps
I just blew my stock cat conv. Can anyone reccomend a quality direct fit high flow cat that really helps perf?
I also cracked my stock exhaust manifold, I am going w/ DC 4-2-1 ceramic to replace. Is it worth it / helpful to use wraps?
Thanks for the help
AB
Wrap, meh, can be a good idea, but if you have a CAI you should be fine. Some would tell you to wrap it to prevent excess heat from entering your engine bay. And certainly without a wrap or heat shield thats true, you will have a more heat soaked bay, so wrapping is your call.
As for the cat? Carsound cats are a good high flow unit, or use stock and get an exhaust shop to try to rig it to your new header. I assume your collector size off this new header is 2.5in?
You can order a custom high flow cat from SMS Products . You just need to tell him the diameter piping, length of the cat, and that you need a 2nd o2 bung for the secondary o2.
Otherwise random technologies is probably your only other option for a direct replacement.
