Old 03-29-2003, 07:52 PM   #1 (permalink)
Car: 99 Si
Mods: jrsc
CSMsi311 is an unknown quantity at this point
A few remaining questions about clutch install
I've been doing a ton of searching and just have a few questions remaining.
1.) According to C-speedracing.com it is a good idea to clean the flywheel, clutch, and pp surfaces to remove oil. Does this mean just excess oil or natural finger oil? What should I use to remove this oil? clean rag, rubbing alcohol??
2.) When you are about to seperate the transmission from the engine. You have the engine supported by a jack.
C-speedracing.com says "Once the jack is in place, remove the engine mount and slowly let the motor drop down by lowering the jack until the motor sits sideways in the engine bay."
I don't understand this step. Could someone please elaborate on this a little more.
Thanks for the help
Jason
CSMsi311 is offline
Old 03-29-2003, 07:55 PM   #2 (permalink)
Car: 1990 accord lx
Mods: finally the H22A is in
fizzbob7 has a spectacular aura aboutfizzbob7 has a spectacular aura about
just make sure it's all clean and maybe even have the flywheel resurfaced by a machine shop.......and after you take the mount loose, the engine and tranny will drop together to a point....when it's at an angle and low enough to slide the tranny off and out, then that's good.....don't let it hang or anything, but the mounts will give enough usually where it will give you some clearance....you'll see when you get to it though..nothing surprising....good luck with it....
kick ass song of the week: I Remember--Loco
DOWNLOAD IT HERE
fizzbob7 is offline
Old 03-29-2003, 07:58 PM   #3 (permalink)
Car: 99 Si
Mods: jrsc
fizzbob7: thanks for the clarification. I do plan on getting the flywheel resurfaced.
Do I need to worry about the engine/tranny sliding off the floor jack?
Jason
CSMsi311 is offline
Old 03-29-2003, 10:39 PM   #4 (permalink)
Car: ebp 00 civic si
Mods: altezza tailights, motech exhaust, moshimoto zx tires, NOS fogger system, 3 spoon engines, and 1 toda sticker
vthokie is an unknown quantity at this point
1) Yes your can apply oil to the flywheel with your fingers, especially because you will be touching dirty surfaces (tranny, engine bay, etc) After putting the flywheel on and torqueing it, clean it with BRAKE CLEANER
2) Yes you can drop it with only 2 mounts supporting it, Only problem is when you put the tranny back on, you may have to jack up the whole engine to make it fit back on the other engine mounts.
Do it fast, Do it furious!!!
vthokie is offline
Old 04-07-2003, 03:37 PM   #5 (permalink)
Car: 99 Si
Mods: Suspension, minor motor work.
PupaScoopa is an unknown quantity at this point
You can pull the transmission without tilting the engine down, have someone above to lower it and someone below to maneuver it around to clear everything.
Red Si
Si Tachometer wall clocks for sale, Click!
For sale: one pair of ITR/LSD Diff bearings (new).
PupaScoopa is offline
Old 04-07-2003, 10:20 PM   #6 (permalink)
SFF900 is a jewel in the roughSFF900 is a jewel in the roughSFF900 is a jewel in the rough
the transmission really isnt that heavy, I can lift one alone piece of cake. I just braced myself, threw my padded creeper underneath and lowered it down to the ground
Halo 2 Xboxlive id= Scotty0
SFF900 is offline
