Old 07-19-2006, 10:52 AM   #1 (permalink)
95vtecsrus has a spectacular aura about95vtecsrus has a spectacular aura about
My Si
For some reason...i think i got a regular civic with a b16 swapped into it...what exactly are some obvious characteristics i dont have a 'fake' si?
1995 Honda Accord Ex 4dr 5spd R.I.P
Damn Semi Truck Re-Treads!!!
2000 CIVIC SI-Electron Blue-Gone but not forgotten
Yer Usual bolt-on Import
1998 Prelude-Hell its blue too!
1998 Mustang Gt-Sounds nice :-)
2005 Yami R6
95vtecsrus is offline
Old 07-19-2006, 10:55 AM   #2 (permalink)
snozepp147's Avatar
Car: 98 Honda Civic ex
snozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep tropospheresnozepp147 In the rep troposphere
gauge cluster, front grille doesn't have H emblem, it'll have the si wheels, does it have any badges on the back? what color is it?
Edit: here's pictures
gauge cluster looks different and says Si on it. they could've put this in their non-si but make sure it has it
do the wheels look liek this
and the grille
Weezer- Rivers' famous sonic blue strat '94-'97
snozepp147 is offline
Old 07-19-2006, 10:57 AM   #3 (permalink)
Black Hole
ezeedee's Avatar
Car: 1994 Ford Explorer
ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?ezeedee you're still here?
whats the VIN?
ezeedee is offline
Old 07-19-2006, 11:51 AM   #4 (permalink)
hm i dont have the vin handy...did some si's come with factory fogs..or did they all have them?
2005 Yami R6
Old 07-19-2006, 12:02 PM   #5 (permalink)
snozepp147's Avatar
it was an option so not all of them have it. if your car has the gauge cluster, wheels and grille that i posted above, and its either electron blue pearl, flamenco black pearl, or milano red. then its most likely an Si. there's no way to be absolutely sure unless you look at the VIN
Old 07-19-2006, 12:03 PM   #6 (permalink)
RedlinedDA's Avatar
Car: scooter
Mods: bell on the handle bars and a sweet basket to carry stuff in
RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?RedlinedDA Why haven't you checked into rep rehab yet?
the vin is the key
RedlinedDA is offline
Old 07-19-2006, 01:24 PM   #7 (permalink)
2000redCIVICsi's Avatar
Car: Millano Red 2000 Civic Si
Mods: Tri Color Reverse glow gauges, Type R red Floormats, AEM V2 CAI, Axle back exhaust, Projectors, Coilovers, B&M Short throw shifter, 4-2-1 Header, LS/VTEC, gsr cams, AEM camgears, si pistons, balanced ls rods, crank.
2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere2000redCIVICsi In the stratusphere
type-r
the seats as well, and look under the back of the car, if there is a swaybar, its an si
-Jarod Culler Cpl/USMC
Former owner of a Milano Red 2000 Civic Si
Now I has a 1st gen Talon TSI AWD
"Most people live their lives wondering if they made a difference, Marines don't have that problem.." -Ronald Reagan, 1985.
MySpace
2000redCIVICsi is offline
Old 07-19-2006, 03:04 PM   #8 (permalink)
yep i know there IS a sway bar back there...okay thanks..i was just curious cause the previous owner messed around with it a little bit and i wasnt too sure...since i was seeing some cars with factory fogs and stuff. Seen an ex which the body looked exactly like mine. oh and im sure its electron blue
2005 Yami R6
Old 07-20-2006, 03:02 PM   #9 (permalink)
HEY...UH CAN I RUN WITHOUT THE SECONDARY O2 SENSOR..IS THERE ANYWAY TO KEEP THE CEL LIGHT OFF WHILE HAVING IT OUT? WITH THE CAT I GOT ITS FACING THE WRONG WAY TOWARDS THE GROUND..
2005 Yami R6
Old 07-20-2006, 03:03 PM   #10 (permalink)
RedlinedDA's Avatar
Car: scooter
you can buy an 02 simulator
Old 07-20-2006, 05:55 PM   #11 (permalink)
VwtoHonda's Avatar
Car: 1999 Civic Si-Totaled :(
Mods: Buy My Parts!
VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?VwtoHonda so um, come here often?
or can get a obd1 ecu i believe will work
N/A is Best
Honda= <3
Going fast in corners is funner than going straight
VwtoHonda is offline
Old 07-21-2006, 10:19 PM   #12 (permalink)
now besides that CEL light coming on...will anything else happen if i removed the sensor for the time being and blocked off the hole? that sensor doesnt have any effect on a/f mixture...
2005 Yami R6
Old 07-21-2006, 10:37 PM   #13 (permalink)
Car: 00 3.2TL
‹^› ‹(•¿•)› ‹^› is an unknown quantity at this point
Check the vin.. If it has EM1 on the vin, then you have a real SI. Plus they only come in EBP, FBP, MRP.
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
‹^› ‹(•¿•)› ‹^› is offline
Old 07-21-2006, 11:09 PM   #14 (permalink)
christian's Avatar
Car: 2005 F-150 XLT
Mods: Beretta-Kimber-Glock-H&K
christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?christian Why haven't you checked into rep rehab yet?
look at the VIN on the dash and there is one on the engine, they should match. If its an origianal car.
Also rear disk brakes.
FYI-99-00 Si's came with the "H" in the grill. Just about everyone took them out.
McCain Palin
One has a crazy face, the other is holding a fish. How can this be a bad vote?
christian is offline
Old 07-22-2006, 06:53 PM   #15 (permalink)
EM1R is an unknown quantity at this point
just make sure the vin has EM1 in it. like 1HGEM10972037927
EM1R is offline
» Site Navigation
» Home
