I had the same problem too, on the #1 cylinder. I pulled the valve cover off, replaced the gasket as well as the gaskets that go where the spark plugs are. End of problem...
hopefully this will help you
Honda Civic, if I took time to list all the mods, you'd be reading for a while....
