Car: performance parts salesman at www.skspeed.com
what are you running tIM?? drag gen III or a custom set up??
i'm going with the greddy kit in may. basically cause i dont want to blow shit up.....i figure 5.5psi will be good for 13's, and i'll hvae a reliable daily driver. then next year i'll rebuild the engine and boost the crap out of it, after i buy the car back off the lease. what i like about the greddy kit is that it comes with an 18g turbo, which is capable of over 20psi very cool
i'm probably also gonna run a nitrous express N-tercooler kit, and try to hit 12's with some slicks
BBBBBOOOOSSSTTTT goooodd......111ft/lbs bbbbaaaddd!!! (greddy kit coming may 16th)
nice custom setup
are you still running stock internals??
how do you like your HKS super sequentail BOV?? what kind of sound does it make?? is it a clean....ppppppssssssttttttewwww. or is it a sqeaky, chirpy, wistly kind of sound?? i'm trying to decide on a BOV, but i dont want my car to have that sqeaky, chirpy, wistly, kind of world rally car BOV sound
What's up Tim, Damn man, I need to catch you on aol some time, it's been a little while. Hows your shit going? Mine is good, remember my hesitation problem? Not rich, I was very lean, hooked up the damn lines to the fmu backwards (stupid me) Oh well, all good now.
99 fbp Si
No longer turbo...type R goodness....
jjjyeaaaahhhhhh
hey clean, you can follow up on my ongoing issue on H-T i have a thread going
Pete, teh SSQV is very fluttery not a squeek, a long pshhhh psshhh pshhh pshhh
almost like 4 releases in one, since it releases in stages, sequentially
2000 Civic Si
DRAG turbo........faster then it looks
Originally posted by Agent Boost Pete, teh SSQV is very fluttery not a squeek, a long pshhhh psshhh pshhh pshhh
oh.....so that's not the kind that i want. thanks for the info
i cant wait till i go turbo i'm so excited
Hey nycivicsi, if i were you, i would go with the same turbo kit that I'm getting....I'm getting the f-max kit this may...it comes with a comression garket which alows you to run 12-13 pounds on a stock engine safely
Originally posted by PimpCivicSi Hey nycivicsi, if i were you, i would go with the same turbo kit that I'm getting....I'm getting the f-max kit this may...it comes with a comression garket which alows you to run 12-13 pounds on a stock engine safely
I don't care what it comes with, running that boost on a stock motor with out a standalone plus top notch tuning will not be safe.
99 fbp Si
jjjyeaaaahhhhhh
hehe compression gasket, think again my friend. no matter how thick that mother is, nothign can save your precious cylinder walls from 12 psi without engine management.
2000 Civic Si
