Old 02-01-2003, 03:06 AM   #1 (permalink)
Car: 2000 Honda Civic Si
k2blksi is an unknown quantity at this point
PCV valve
Anyone know were its located and how to check if needs to be replaced.
k2blksi is offline
Old 02-01-2003, 05:13 AM   #2 (permalink)
b16a2racer's Avatar
Car: 2001 Audi TT Roadster Quattro
b16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond reputeb16a2racer has a reputation beyond repute
a bad PCV valve sometimes causes decreased gas mileage. do yourself a favor and CHECK FIRST to see if it needs to be replaced.
TO CHECK: at engine idle, lightly pinch the hose connecting the PCV Valve to the Intake Manifold. If there is a clicking sound coming from the PCV valve, it's fine. If not, you may need to replace the PCV Valve.
New PCV Valve (~$3 aftermarket, $14 OEM Honda Part)
1. look at the throttle body assembly. you are going to see a mess of vacuum hoses running all over the throttle body, the one that you need to be concerned about is the hose that's on the right hand front side of the throttle body.
2. once you find that hose follow it down to the intake runners. The hose will lead you to the left (passenger side) of the engine, kind of right behind the oil fill cap.
3. the PCV valve has a 90 degree bend on the top of it were the vacuum hose from the throttle body hooks to it.
4. the easy way to remove the PCV valve is to gently rock it side to side as you pull upward. once you have it out, you can disconnect the vacuum hose from the throttle body.
b16a2racer is offline
