11-03-2004, 11:51 AM
#1 (permalink)
*****istrator
Car: 2005 Acura RSX-S
Mods: OEM Body Kit
Primary and Secondary 02 sensors??
Can I use my secondary 02 sensor in place of my Primary? I currently am running a p-28 with a high flow cat so i dont have a secondary 02 hooked up. i think my primary 02 may have taken a shit, so can i use the secondary in its place or are they different???
08 Infiniti G37S
05 NBP RSX-S -Traded in
2000 EBP Si
STOLEN 11-21-04
Team OG
11-03-2004, 03:52 PM
#2 (permalink)
*****istrator
Mods: OEM Body Kit
ok im pretty sure you can, from what I read they are the same except for the length of the wire
08 Infiniti G37S
2000 EBP Si
STOLEN 11-21-04
Team OG
11-03-2004, 04:49 PM
#3 (permalink)
you might be able to, but i think they have different part#s
silence is golden
but duct tape is silver
11-03-2004, 05:36 PM
#4 (permalink)
*****istrator
Mods: OEM Body Kit
Yeah the different part numbers as far as I know are because they have different length wires. I'm 99% sure that they are interchangable.
08 Infiniti G37S
2000 EBP Si
STOLEN 11-21-04
Team OG
11-03-2004, 05:40 PM
#5 (permalink)
only one way to find out
silence is golden
11-03-2004, 07:58 PM
#6 (permalink)
I can't give you a definite answer...but...
I mean... an o2 sensor is an o2 sensor....they are both narrowband...so...
poo.
uɐsnɹnƃgurusan
Teal Civic Sold: 08/31/2006
FOLD FOR SHO! TEAM 54075
folding@home
11-04-2004, 08:50 PM
#7 (permalink)
Mods: STOCK
in my emissions class..i believe they are different on most cars. one is to measure before the cat and one is to measure whats coming out.
so im not sure on that one for sure...but if they are different part numbers then theres a reason for it.
11-05-2004, 12:52 AM
#8 (permalink)
Car: 99 FBP Si
Mods: RS*R ExMag, K&N drop-in, H&R Cup kit, 16" Kosei K-1's with 205/45R16 Dunlop FM901's, oem fogs, rear lip
Upstream is for fuel trim, downstream is for monitoriing whether or not the catalytic converter is doing it's job.
- 2003 Flame Red Jeep Wrangler Sport -
- 1999 Flamenco Black Pearl Civic Si - [sold]
- 1997 Milano Red Civic EX coupe 5spd - [sold]
Marc
11-05-2004, 06:41 AM
#9 (permalink)
*****istrator
Mods: OEM Body Kit
Ok so will it work or not?? I realize that the two locations play different roles, but is it the location where the 02 is plugged into that makes the difference or is it the actual 02 sensor itself?
08 Infiniti G37S
2000 EBP Si
STOLEN 11-21-04
Team OG
11-05-2004, 12:42 PM
#10 (permalink)
Car: 04 EP3
Mods: Greddy Evo; Comptech IceBox; sweet-ass removeable JDM Graco Infant seat (+50hp yo)
i would think they are not interchangeable. i checked out oxygensensors.com and they specify Primary or Secondary.
Link
11-05-2004, 06:49 PM
#11 (permalink)
Mods: STOCK
so im right?
but the question is will it work. im not positive on that answer if it would work switching them
11-06-2004, 10:03 PM
#12 (permalink)
Car: 99 FBP Si
so im right?
Right.. the upstream measures the amount of oxygen in your exhaust stream. It doesn't know the exact A/F ratio, but it knows whether or not the car is running rich or lean depending on the voltage it's putting out. The only oxygen sensor that will read the exact A/F ratio is a wideband O2 sensor. Anyway, the upstream can tell whether the car is running rich or lean and sends that info back to the ECU, where changes are made, controlling your fuel injectors' pulse width (how much fuel's being sprayed), in turn trying to get the mixture back to stoichiometric. And yeah, the downstream just measures oxygen levels in the exhaust after the cat to make sure the cat is actually working and reducing the amount of bad emissions coming out the tailpipe.
Marc
11-06-2004, 10:05 PM
#13 (permalink)
Mods: STOCK
yea i get what ur saying but are they interchangable thats what im wondering?johhny tran saids it not the prob but im wondering if they are the same sensor? even though they measure different things in different spots but are they the same sensor
11-09-2004, 09:02 AM
#14 (permalink)
Car: 99 FBP Si
Yeah, an oxygen sensor is an oxygen sensor. Unless the car uses a wideband sensor (which it doesn't) then it's usually the upstream and a regular O2 sensor is used downstream.
Marc
