Serious Tech Question, b16A2 Trouble
Ok, Here is the deal and I appreciate any help before I spend $600 on the parts I think I might need.
I have a B16A2 swap that ran like a champ for the last year since I did the swap. Lately though its been running like crap. It only has 50k miles on it. It lopes and misses at Idle really bad. Here is what I have done.
Relpaced Cap, Rotor, Spark plugs and wires...
Checked all fuses (good)
Checked Fuel injectors and pump, functioning properly
Compression check done, everything OK
Timing checked and rechecked, top dead center and good
I cant get the fault codes because the ECU that came with the engine was from a 1997 Civic Del Sol (European Spec). See I had the swap done while I was in Germany. My whole car was striped to bare metal, and when the swap was put in, the Del Sol's wiring harness/ECU/Guage Cluster were used. Anyways....So by process of troubleshooting with manual and much work here is my theory. I believe it is the TPS (throttle position sensor). After following the steps in the manual which shows how to adjust idle, the idle failed to move above 500 RPM. The case on the TPS is cracked and turning the screw all the way in and out to adjust the throttle had no effect. I'm assuming that this tells the PCM (Program Control Module) about how much air is coming through the intake and in turn the amount of fuel is sent out through the injectors to achieve the correct mixuture.
SO if this is malfunctioning, I might get the bad idle, and the car is running like super rich. The TPS must be replaced in conjunction with the Throttle Body, so thats what I'm assuming I need to replace. Everything else is good and running fine. The thing is before I spend $400 to $600, I'd like any second opinions to confirm or shoot down my suspisions. If I do have to buy a new Throttle Body, I might as well go for and aftermarket one, but do they come with a TPS or what?
Thanks so much in advance
(If you read this post and have no clue but no someone that might, I'd appreciate you forwarding it to him/her)
Honda Civic, if I took time to list all the mods, you'd be reading for a while....
