Just curious, because I really want an S2k but I don't have enough $ for a down payment and to pay off my truck. So I was considering it...in the very very back of my mind, but I don't think I could do it...anyway what do you think I could get out of it? Motor has maybe 3400 miles on it, car has like 170,000ish miles
The Mod List
THE CAR:
1993 Honda Civic Si Hatchback
JDM Foglights
Buddy Club Pro Spec Exhaust
Buddy Club P1 Racing+2 15x6.5" Wheels in Hyper Gold
Carbon Fiber Duckbill Spoiler
The Suspension:
Omnipower Upper Control Arms
Omnipower Coilovers "Sport Kit" 12kg front 10kg rear
Neuspeed Front Strut Tower Bar
Cheap Rear Strut Tower Bar
The Engine:
B20B4 Block Zyglowed, Bored & Honed to 84.5mm with Torque Plate, Align Honed, Hot Tanked, Surfaced & Decked
Crank Magnafluxed, Balanced, Micropolished
Clevite Rod Bearings
Clevite Main Bearings
ARP Head Studs
ARP Main Studs
ARP Rod Bolts
ARP Exhaust Studs
Forged 4340 Eagle Rods
JE Forged Pistons 11:5:1 Compression Ratio
ITR Water pump
Integra C&R Racing Aluminum Radiator with SPAL fan
ITR Oil pump
Prodrive Oil Pump Gear
ITR Timing belt and new Belt Tensioner
Golden Eagle LS/VTEC Conversion Piece
Endyn Crankcase Breather Kit
Cometic Head Gasket
2000 JDM ITR Cylinder Head (Stock til I get money for headwork and cams)
Megan 4-1 2.5" Collector Header (POS i know but this project literally broke the bank)
Megan test pipe
Hondata Intake Manifold Gasket
AEBS Intake Manifold Port matched to STR Throttle Body
AEM SRI Intake
STR 70mm Throttle Body
SiR2 TPS
OBD1 1994 GSR Distributor
OBD1 Integra Alternator
Hasport Engine Mounts
Spoon Sports Magnetic Drain Plugs to filter metal break in shavings
99 Civic Si Starter
Engine Tuning and Monitoring:
PLX M300 Wideband O2 Sensor and Controller
Hondata S300 System
Autometer Carbon Fiber Oil Pressure Gauge
Autometer Phantom Oil Temperature Gauge
Jegs Fuel Pressure Gauge
The Fuel System:
Walbro 255LPH Fuel Pump
Holley Adjustible Fuel Pressure Regulator
STR Fuel Rail
Precision Engineering 440cc Injectors
Russell Stainless Fuel Line
New OEM Fuel filter
The Drivetrain:
1996 Integra Type-R Transmission with LSD
AI4-HDR6 ACT 6 Puck Clutch with Heavy Duty Pressure Plate
ACT Streetlite 12lb Flywheel
Driveshaft Shop Stage 2 500hp Axles
