Old 08-01-2005, 06:38 AM   #1 (permalink)
toostock's Avatar
Car: 2000 EBP SI
Mods: Crack in Windshield
toostock is a jewel in the roughtoostock is a jewel in the roughtoostock is a jewel in the rough
SI burning oil at 63k?
So, i got my 00 EBP Si with the standard B16A2 in it about 2 months ago. I had the oil changed right away and have been checking it since. I checked it on friday and the stick was almost bone dry. I put a few more quarts in and checked it again. I was driving home yesterday and my girlfriend said that i was smoking quite a bit under hard acceleration. I dont beat my car, but i do try and hit Vtec once in a while. I checked the oil again, and it seemed to be at the same level as when I filled it. Is this normal for these motors, I know the person before me took care of it...any advice?
toostock is offline
Old 08-02-2005, 12:24 PM   #2 (permalink)
Car: 2000 civic si
Mods: short shifter, cold air intake, strut bar. thats it so far doing more though
1CivicSi1 is an unknown quantity at this point
do you have an oil leak?leaks can be at gaskets....you should check your spark plugs see if they have oil on them if they do could be worn piston rings, or bad valve seals or guides.... and no its not normal for that motor to eat up oil like that...hope it helps and good luck fixing it.
1CivicSi1 is offline
Old 08-02-2005, 12:29 PM   #3 (permalink)
HondaVTEC93's Avatar
Car: 2006 Honda Civic Ex
HondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problemHondaVTEC93 has a Rep problem
hmmm check for leaks and dont beat it. let us know what u find.
2000 Elantra - demolished
1993 Civic Ex - built then sold
2006 Civic Ex - current
HondaVTEC93 is offline
Old 08-02-2005, 02:09 PM   #4 (permalink)
Dang Civic's Avatar
Car: 2006 Honda Civic SI
Mods: DC Sport Race Headers, Megan Mid Pipe, Tanabe Exhaust, Injen CAI, 17" Enkei Wheels
Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?Dang Civic What did you do to deserve all this rep?
Its quite normal on these cars to tell u the truth. Mine really didnt start burning till 80k or so. My oil change intervals has changed to 2500 miles now instead of 3k. I use mobil one syn too. She still drives good and strong so its worth it to me to change oil every 2500. I normally add a quart after a 1500 just to make sure it'll make it to 3k with out blowing my motor up. I think its its the valve seals that give out quick on honda's. My acura gsr is almost just as bad but then for gsr's, burning oil is about normal from the factory.
92 Integra Ls ...My current Project...so far...
Cross Drilled Rotors, Xenon bulbs and smoke gray turn lamps and amber corner lamps. Ebay short shifter lol.
Future mods....thinking turbo......and a paint job...
Dang Civic is offline
Old 08-02-2005, 03:45 PM   #5 (permalink)
toostock's Avatar
Car: 2000 EBP SI
thats what I thought, my CRX burned like a bitch. Im gonna do a compression test for the hell of it. thanks guys.
BTW, no oil leaks! im anal about that.
toostock is offline
Old 08-02-2005, 11:44 PM   #6 (permalink)
i dont burn any
Old 08-04-2005, 04:12 PM   #7 (permalink)
GunMetal Member
Car: 2000 Si..It's blue damn it!
Mods: Almost stock?
SiNergy will become famous soon enoughSiNergy will become famous soon enough
how many miles have you driven since the oil change. Ever since I got my Si it goes through about 1/2 qt every 2k miles AND I change my oil at 4k. A 1/2 qt is within reason between oil changes, if you are losing more than that then look for leaks then get the the compression checked.
SiNergy is offline
Old 08-05-2005, 06:24 PM   #8 (permalink)
Dark Wind
iLLeFFeKt CiViC's Avatar
Car: 93 civic dx
any leaks under the car?
take the spark plugs out and check them out, run a compression test followed by a leakdown test.
1991 Galant VR-4
1989 Camry -daily beater
1993 Civic dx-sold
1991 Eclipse gsx-sold
iLLeFFeKt CiViC is offline
Old 08-12-2005, 06:41 PM   #9 (permalink)
Car: 2000 Civic Si
SweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphereSweetEBPSi In the stratusphere
I'm sorry to ask the obvious question, but what color of smoke was it? White or dark/black?
SweetEBPSi is offline
Old 08-15-2005, 05:27 AM   #10 (permalink)
toostock's Avatar
Car: 2000 EBP SI
White-ish/ Gray-ish smoke only after about 6k rpm...
toostock is offline
Old 08-15-2005, 02:46 PM   #11 (permalink)
jon
jon's Avatar
if it was oil, the smoke would be blue, ususally when you have a white smoke, that is coolant
silence is golden
but duct tape is silver
jon is offline
