When you go boost and spray you run into 10X the problems you would if you did one or the other. Im going to advise against it. I would personally build it for boost. JE Rods, Pistons, rings, head gasket, IM gasket, cam seals ( front main ), distributor seal, rear main. Do a minor head build, valves, springs, retainers, 3 angle valve job. then a simple greddy kit at 14 lbs shouldnt be too bad at all.
