Sway bars usually shift a little bit inside the bushings, but they shouldnt move too much. I'd be careful if i were you tho, because Si's are known for their subframe tearing out with larger sway bars. If theres that much suspension travel, then you're probably putting a lot of strain on your rear subframe.
-Bobby
2000 EBP Civic Si
