its cool, with a dual filament bulb, if u look at it, there are two sep. coils that can light up inside the bulb. these types of bulbs are usually used in a light set up where the same bulb has to be used as a parking light, as well as for a blinker. the dual filament bulb will light up one of the coils when you turn your lights on, and the other coil will only be used when a turn sig. is activated. so the light will continuously remain on and still flash at the same time...the single filament bulb is usually used if a light is ONLY used as a blinker, and therefore only needs one coil to turn on and off in order to flash...hope this helped
