Originally posted by k2blksi
I just got back from the shop and was told I needed an input shaft bearing. I went there assuming I needed a belt or pulley. The car makes a whining screeching sound coming from the belt area. So now the tranny needs to be dropped and I should have them do the clutch too. What is a good clutch to get? Also if anyone has heard of this prob before how much longer can I drive the car before it breaks?
The main (input) shaft bearings support the main shaft in the tranny. There are two bearings, one on either side of the shaft. How often does it make noise? If you push the clutch pedal down, does the noise stop?
How well do you trust this shop? Personally, I'd have another shop check it out too. Lotta time and $$$ to replace these bearings.
They are number 1 and number 23 in the pic. 23 is the clutch side of the main shaft.
