Originally posted by BennySiR
I though it was a combination of oil temp and pressure..because when you start your engine that is when you have the highest oil pressure....but when your car isn't warmed up...you can't hit VTEC..so someone straighten out....
you are almost correct sir.
the engine does not have an oil temp sensor. however, there is a water temp sensor. vtec will not engage until the motor is sufficently warm as indicated by the coolant temp. Furthermore, in the event of low oil pressure, vtec will not engage.
6spd, 8000rpm ep3 sucka.
First cammed k20a3 183whp/143tq, stock block, no head porting
You can take me out of the race, but you can't take the race out of me
I'll fuck you till you love me, faggot - Mike Tyson
