Originally Posted by pinasb16a
type r piston
crower camshaft 63402-2 stage2
crower valve spring and retainer
Theres your problem!! you only have 1 piston, 1 cam on a b series, and only one valve spring and retainer!!!! :bh
On a more serious note, your car needs to be tuned on a dyno to see results. Also, you could probably use more fuel, or at least something to measure how much fuel you are getting, and a larger IM to go with the TB. May i also suggest engine management if you dont already have any, obd1 conversion with a p28 is a popular choice for the b16's.
