being broke and horsepower don't exactly work out. i'm telling you from experience.
truthness.
-depending on your climate, you can doo the TB coolant bypass.
-if you know what you're doing, you can rebuild your engine and throw in some new goodies (higher compression OEM pistons).
-definatly make sure al maintnace is up to date. No point in bolting on a header if the oil is 9000 miles old.
Originally Posted by life sux die
also, there is no such thing as an "EG Coupe" as your screen-name states.
Mods: Tri Color Reverse glow gauges, Type R red Floormats, AEM V2 CAI, Axle back exhaust, Projectors, Coilovers, B&M Short throw shifter, 4-2-1 Header, LS/VTEC, gsr cams, AEM camgears, si pistons, balanced ls rods, crank.
cheap speed, Nitrous will make you fast for relativly cheap. if you rtalking about comparing to swaps or turbo. but it can blow your shit up if its not done correctly or if you rmotor isnt in the best of shape. do the basics for now, tune ups and such, get plugs and wires, header, intake and exhaust, then save up for cams and intake manifold. after that you can go a few routes, chip your ecu or go stand alone and boost it, or get it ported and polished and go with a better valvetrain. There tons of ways to go. Do the basics first, then figure out which method of speed you want. start saving.
-Jarod Culler Cpl/USMC
Former owner of a Milano Red 2000 Civic Si
Now I has a 1st gen Talon TSI AWD
"Most people live their lives wondering if they made a difference, Marines don't have that problem.." -Ronald Reagan, 1985.
