Originally posted by SpeedxRacer
Double check your wiring behind the deck to see what you did. You should use the ACC or remote turn on switch to turn on your CD player. Did you splice it into your ignition? Could you clarify your post... its kind of hard to understand.
Ya, your shouldn't have to disconnect your ground to turn off radio. You have both power wires hooked up to a constant source. One wire should be constant and one is ignition so that it'll turn on when you start car. I don't know the colours because I don't know what deck you're talking about. Usually red and yellow, one of these should be constant and the other not.
