do you have the radio cage? it is a metal sleeve that fits around the radio and has an 1/8" lip that keeps it from sliding back into the dash and tabs that you bend out to hold it in the dash. it also has tabs that lock into the radio when you slide it into the cage (you need keys that come with the radio to remove it).
if you have a jvc you should be able to use one from any pioneer, kenwood, newer (05+) alpines, and jvc (of course). most car audio shops should have some laying around (they might charge you $5 for it)
you should be able to get a universal pocket that will fill the other hole, too. expect to pay around $15 for that.
James Stanton
