Integra Stock Radio Removal Guide - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Performance - Tech > Appearance & Sound > Car Audio & Electronics
Old 10-13-2008, 03:11 PM   #1 (permalink)
Car: 1999 Acura Integra
Mods: None ATM
tacojose is on a distinguished road
ok so today i decided to make a guide on how to remove the stock stereo in my integra (1999 integra gs) but it will work on other integras.
i took out the entire center console it might not be the easiest way but it works
Step1:Slide both of your seats all the way forward then take out the 4 screws on both sides of the center console
Step2:Next go to the little dip where your ebrake is and remove the screw cover and there will be 2 screws that you need to remove
after you removed those screws you can remove that part of the console by sliding it back and and lifting up
Step3:Now remove your shifter knob then go to the back of the console and there is 1 screw on each side of it, you need to remove them
Step4: Now remove your ash try and unhook the harness connected to the lighter.
Step5:Next there are two screws behind the ash try you need to remove those. Also there are two screws on the inside of the ash try you need to remove.
Step6:After you remove all those screws you will be able to remove that section on the console and it will look like this
Step7: Now your going to have to get turned upside down almost to get to see these screws to unscrew them to let the radio loose and after you loosen these you will be able to slide your radio out and your done
I hope this guide helps and any questions ask away
o and yes i know my car is super dirty
tacojose is offline
