Mods: Short shifter, custom intake piping aem air filter, dc exhaust, tokico springs and shocks, enkei wheels wrapped in falken rubber, pioneer system
Need Help!!!!! Bad Charging System
sup i posted about this in the acura sextion but suggestion of whats wrong dont help. My charging system doesnt work, i checked alternator its good, the battery wires are good the fuses are good any ideas
Car: 2006 Dodge Ram 2500 CTD(Weekend Warrior)TORQUE UP THE ASS!!!93 Civic LX (Daily Driver)
Mods: AEM intake,Edelbrock Header,NGK B18 Spark plug wires,Drop kit,17" Rota Torque wheels,Smoked LED tails,Smoked Turn Signal lamps,8000K HID's Hi/Low kit
There is a big chance its your battery.It probably can't hold charge.Does your car turn on at the turn of the key? It could also be you don't have proper gound from the battery to the chassis.
when its on idle the rpms go up and down, i checked the volts on the battery and it read 12.6, i let it idle longer to see if it would go up and then it read 12.2. When i charged the battery it was ok the system messured 13.6, then i started driving again and the battery light came on. I got the alternator tested its good checked for resistance in the cables to the alternator and back there isnt any, only thing i think it might be is the regulatoir in the alternator but since the test on the alternator is good im in ????????
