Go Back   Honda Forum / Acura Forum - SuperHonda.com > Performance - Tech > Car Audio & Electronics
Old 07-05-2004, 01:28 PM   #1 (permalink)
Dark Wind
The_Producer's Avatar
The_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphereThe_Producer In the rep troposphere
Seperate amp for FRONT sub, not rear sub???
I have a question, I have a subwoofer (10" 4-ohm") setup in the back trunk of my car. I am adding a subwoofer up front in the center console, but the sub is going to be 8-OHM, do I have to get a smaller single channel amp for that sub, or can I get another amp that will power that sub and the other component speakers, etc?? I would like the rear trunk to be seperate from the front stuff. The amp in the back is a single channel amp as well. The sub up front will be a 6.5" Rockford Fostgate HE Punch and I think 8-ohm...
thanks for the help!!!
The_Producer is offline
Old 07-05-2004, 08:21 PM   #2 (permalink)
acuradriva's Avatar
Car: 98 GS-R
you can get a single channel or a 4 channel. if you use the 4 ch you can use the front output for the components and the rear channels bridge to the sub.
acuradriva is offline
Old 07-05-2004, 11:14 PM   #3 (permalink)
Dark Wind
So I would be better off just using 3 amps. For ease of use? A single for the rear sub, a single for the front sub, and a two channel or higher for the mids/highs right?
Old 07-06-2004, 12:11 AM   #4 (permalink)
Car: 2006 Civic SI
Mods: Greddy Evo 2, DCRH, and K&N Typhoon V2.
organiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to beholdorganiz3d_chaos is a splendid one to behold
the easier way would be to get a 4 channel and use the front 2 channels for the mids and bridge the rear 2 for the sub
Originally posted by vinces ass
chaos > all.
organiz3d_chaos is offline
Old 07-06-2004, 07:38 AM   #5 (permalink)
Dark Wind
how exactly do you 'bridge' again?
Old 07-07-2004, 04:12 PM   #6 (permalink)
VTECnicalAccord's Avatar
VTECnicalAccord has a spectacular aura aboutVTECnicalAccord has a spectacular aura about
Dude, just read the turorials already. No offense, but a lot of your questions are basic and are covered in the stickies. Again, no offense, so don't take any or flip out about it, I'm just offering some helpful advice.
1999 Accord Coupe 4 cyl.
Denon DCT-R1
PPI DCX-730
Hertz
PPI Pro 10
(2) PPI A600.2s
Stinger Expert
VTECnicalAccord is offline
Old 07-07-2004, 05:42 PM   #7 (permalink)
Dark Wind
i browsed through them already, couldn't find a glossary of terms or anything to tell me what it is and what it does.
Old 07-07-2004, 06:27 PM   #8 (permalink)
http://www.bcae1.com/
Straight from the sticky.....all you need to know about most everything......study up.
Denon DCT-R1
PPI DCX-730
Hertz
PPI Pro 10
(2) PPI A600.2s
Stinger Expert
Old 07-07-2004, 06:39 PM   #9 (permalink)
Car: 1995 3000GT
teg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud ofteg711 has much to be proud of
http://www.crutchfield.com/S-MEgXYIiU7tV/tech/kb38.html
I'm not familiar with that sub, you might want to look up the model # and check the specs and requirements.
However I am assuming it is probably no more than 150 watts and runs at either 4 or 8 ohms.
You mention having component speakers. Do you have one pair (front) or two pairs (front and back). Regardless of whether they're components or not is whether or not you plan on "amping" them i.e. hooking up each side to an amplifier channel i.e. left front = 1 channel, right front = 1 channel, left back = 1, right back = 1
If that's the case I would look in to a five channel amp. They will usually have something like 50x4 and then a subwoofer channel for small subs.
Or if you are only planning on having one pair of speakers amp + the front sub, you could probably just use a 4 channel, 2 channels powering the components and bridge the other 2 remaining channels and hook your sub up. However if you end up doing that I urge you to get a better understanding of what exactly your sub and amp can do impendance (ohms) wise.
Hope that helps a little.
teg711 is offline
