The sub itself will not be able to be wired to the deck itself, you need to get an amp to power it. You can wire an amp to the stock deck, you just need to get a Line Out Converter(LOC), you can pick that up for about $10-20. What the LOC does is, convert the speaker signal into a RCA signal. Although some amps can accept speaker signals as an input, if yours does, then you don't need the LOC.
