Old 11-04-2003, 07:31 PM   #1 (permalink)
mls
Dark Samurai
mls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to beholdmls is a splendid one to behold
height adjustable suspension care
Is it best to spray a lubricant on the thread body to prevent the threads from chewing each other up? The downside I see by using a liquid type spray, is it will attract all forms of junk (such as sand), which will just chew up the threads anyway, which will make using the lubricant pointless in the end.
If you look at the suspension, as you rotate the height adjustable collar, the thread is under load, so I assume that eventually the thread might destroy itself after repeated adjustment without lubricant. My sisters Mag Lite's end cap thread is basically ruined (the aluminium threads are chipped & rough & just barely work) because she never lubricated it, & if you look at this as an example, the Mag Lite thread does not take as much load as a car suspension thread.
Is there a dry type lubricant you can use? When I used to be into mountain biking, I used a dry type lubricant on my chain, called Krytech made by Finish Line. It went on in a liquid, but it dried up & looked all the world like melted candle wax. This lubricant was ok, but liquid still worked better for my chain. The downside I see to a dry lubricant is that the thread will probably just wear/flake (whatever) the lubricant off. Can you use graphite powder?
mls is offline
Old 11-05-2003, 11:19 PM   #2 (permalink)
ArtcbluRsx's Avatar
Car: 02 Acura Rsx Type-S
Mods: Injen sri,Tein SS-P, Spoon N1 Axle-back exhaust,17x7 5Zigen FN01R-c, CFR pulley, Spoon upper rear strut, Spoon lower tie bar, Spoon front upper strut, Tanabe X-brace, ITR shift knob, 22mm ITR rear sway, Mugen Rear upper strut,Toda Engine Kit soon =)
ArtcbluRsx is an unknown quantity at this point
even if you do get some mud onto the threads..its better than nothing since the mude will work as a shield against water n stuff (granted that the mud is just the lubricant+rocks n crap)....just spray the threads with wd40..then use a toothbrush/rag to clean it periodically and you'll be fine...
Toda Power, Tein , Spoon, JDM , Tanabe, 5Zigen , Injen
ArtcbluRsx is offline
Old 11-08-2003, 04:41 PM   #3 (permalink)
Car: 04 s2k
jdmhonda98 is an unknown quantity at this point
IF YOU HAVE GOOD QUALITY COILOVERS LIKE GROUND CONTROLS YOU WILL NEVER HAVE PROBLEMS BECAUSE IT'S GOOD QUALITY ALUMINUM, AS LONG AS YOU TIGHTEN THE ALLEN SCREW THE THREADS WILL NEVER MESS UP.
jdmhonda98 is offline
