Old 05-02-2002, 10:04 PM   #1 (permalink)
ebm
ebm is an unknown quantity at this point
HELP! My sway bar hits exhaust
Help, i have a problem that is pretty bad. I have a 99 Civic Ex and I just put on the 99 Civic Si rear sway bar. When turn hard left or have people sitting on the passenger side, the sway bar hits the exhaust piping that is going to the muffler (Apex'i WS) at the corner part of the sway bar, so at the joint. I have prokits on stocks if that helps. But i dont know what to do. Is this because of the lack of grease that is missing on the sway bar? I put some wd-40 to test out but it still happens when i am just sitting there idling.
eBm
ebm is offline
Old 05-02-2002, 10:47 PM   #2 (permalink)
Location: chair, room, apartment, gainesville, florida...etc
PseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these partsPseudoRealityX is infamous around these parts
get an exhaust shop to weld on some new shorter hangers for the exhaust.
Jesse
#129 E-stock
The weapon...(updated)
"racing makes herion addiction look like a vague desire for something salty" [paraphrased]
-peter egan
PseudoRealityX is offline
Old 05-03-2002, 12:14 PM   #3 (permalink)
ebm
how much does it cost to get shorter welds? my exhaust doesn't hang that low but i guess low enough.
eBm
ebm is offline
Old 05-03-2002, 01:14 PM   #4 (permalink)
probably about 25 bucks...if that.
Jesse
#129 E-stock
-peter egan
Old 05-03-2002, 08:32 PM   #5 (permalink)
Car: 96 civic dx
Mods: i/h/e msd ext.coil,wires,ignition sys,front&rear sway bars front upper rea lower tie bars.soon to drop in gsr motor and auto to manual swap $5,000
flymecourageous is an unknown quantity at this point
exaust pipe bend
it will need to curve up more and a shop like midas around 40 also you can use lock lubricant [graphite] in a spray works great
flyme
flymecourageous is offline
Old 05-04-2002, 03:26 AM   #6 (permalink)
Car: Honda
Ryocross is an unknown quantity at this point
You wont even need a weld.
You cant weld t304 stainless with a gas torch, so they will use an adjustable strap and drill it into the frame, and then tighten it like a belt up closer to the frame, expect 50$
If this does not work you have 2 choices, dump the sway bar or have the exaust cut and rewelded with a slip, to clear any sway bar.
Ryocross is offline
Old 05-04-2002, 05:12 PM   #7 (permalink)
ebm
ok, i just took the sway bar off for now, so i will consider my options first.
eBm
ebm is offline
Old 05-04-2002, 05:56 PM   #8 (permalink)
Car: Honda
I can tell you I had all three done, I had my exhaust cut and re-welded to clear the bar, then a custom hanger and then wound up taking the bar off, what a waste of money
Once you have a very stiff suspension the rear sway bar is not warranted anyway, although the Si bar is a pretty good size. Regardless of suspension mods.
Ryocross is offline
Old 05-04-2002, 10:33 PM   #9 (permalink)
ebm
thank you, i will keep that in perspective. i think i was just going to give it away.
eBm
ebm is offline
Old 05-06-2002, 11:24 PM   #10 (permalink)
anfrey's Avatar
Car: clover green pearl ej8
anfrey is an unknown quantity at this point
if you're giving it away, i'll take it
" . . . set - the - gearshift - to - the - high - gear - of - your - soul . . . "
anfrey is offline
Old 05-06-2002, 11:30 PM   #11 (permalink)
ebm
hahahaha..u wish...nah i am just going to give it to my gf.
eBm
ebm is offline
Old 05-07-2002, 12:29 AM   #12 (permalink)
Once you have a very stiff suspension, you no longer have a very streetable car.
Jesse
#129 E-stock
-peter egan
Old 05-07-2002, 04:27 AM   #13 (permalink)
anfrey's Avatar
ah damnit!!!
anfrey is offline
