Old 04-20-2008, 05:41 PM   #1 (permalink)
SuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problemSuperAkuma has a Rep problem
How bad is it to mix tires?
Just bought a used 5th gen prelude from a friend. Today I noticed that the two front tires are kinda bald and ther rear are still very good. I thought no problem I will just go to the tire shop and buy another pair of the same tires.
Well there is a problem, Dunlop no longer makes the FM901 and whatever left over stock that the shop have, that is all that they have. No shop around here have the size that I need. I checked many online tire retailers and none of them have them listed in stock. The size that I need is 205/50/16.
Since I spent all of my money buying the car, I don't have much to buy a full set of GOOD tires. Also I don't want to throw away the tires that I have in the rear because like I said, they have lots of thread life left over.
So how bad is it to mix tires? Since the car is FWD, is it okae if I keep the two front the same thread and the two rear the same thread? I don't race the car, I use it as a daily driver, mainly to work which is just a few block away. But every other week I drive to the bay area, about 100 miles away.
Would it be ok if I just get two good tires for about $100 each, or should I replace all 4 with some really cheap tires like kumho?
SuperAkuma is offline
Old 04-21-2008, 01:21 AM   #2 (permalink)
lippstuh is on a distinguished road
i think as long as the front tires are the same. not all tires are the same even if they have the same size, they have different weights, and a lot of other sh*t.
all i know is that you can't run stag. set up w/ awd, so i guess that theory applies here as well
lippstuh is offline
Old 04-21-2008, 07:06 AM   #3 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
Mixing tires is a bad idea.
Think about it like this. Would you put a running shoe on one foot, and a sunday dress shoe on the other and go for a jog?
If you mix, then you need to keep all tires similar. if dunlop discontinued that tire, then they most likely have a replacement that is in the same class.
If you decide to get 2 completely different tires, then you need to replace the rears with the same tire asap.
No matter what, you need to keep the same condition matching tires on the front.
kommon_sense is offline
Old 04-21-2008, 11:35 AM   #4 (permalink)
Your analogy of the running shoes does not make sense. So if you put on dress shoe on both sides it is fine to go jogging?
jk
But I understand what you are saying.
Dunlop discontinued the FM901 and they replaced it with the SP MAX. The thread design is a little bit different compared to the FM901. I emailed dunlop about this to see if they can find me a pair of the FM901 in the size that I want. For the mean time, I will just roate the tires and put the good on to the front.
I am not really a big fan of these tires. But the fact that I don't have $400 to replace all four wheels, I need to make with what I have. They are pretty loud and the wet grip is pretty lame. I am not the only one that said this. My wife's(gf at the time) dad had an 99 M3 with those tires. He said it was the loudest tires that he ever had and did not like the traction in the rain. After 3 month he replaced with with some Michelin tires.
Old 04-26-2008, 02:28 AM   #5 (permalink)
mad-ass's Avatar
Car: 1995 Nissan 240sx
Mods: Circuit Sports Exhaust/5 lug hubs/RUCA/front strut tower bar/V2 Short Shifter, Stance GR+, Techno Toy Tuning Subframe Collars/TC Rod, Welded Diff, Z33 Inner/SPL v5 outter Tie Rod, White line rear sway bar, 5spd conversion
mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?
I do it all the time, matter of fact, that's what I do with my car at all times.
front's are toyo proxies and rear's are bridgestone r-03's
ooh..tires are herra expensive..[god damn drifting]
My S14 Build Thread
mad-ass is offline
Old 04-26-2008, 07:27 AM   #6 (permalink)
I was doing a track event one weekend and a guy had mixed tires. I'll dig around and see if I can find the picture where he went nose first into the tirewall...
Old 04-26-2008, 04:57 PM   #7 (permalink)
mad-ass's Avatar
it'll be different for what kind of event you are entering and what type of car you have[FR or FF or RR] and as far as my FR car goes as S14:FR car layout goes, mixed up tires are fine, as long as they match from front two are same and two rears are same. but that's from my experience as drifting track experience. but at all times, you should matching tires.
My S14 Build Thread
mad-ass is offline
Old 04-26-2008, 05:36 PM   #8 (permalink)
EnJoiThaRex's Avatar
Car: 1988 CRX SI
Mods: D15B2 w/PM6: pacesetter headers, tanabe 2 1/4 exhaust system, ZC tranmission, B&M short shifter, "Custom Shift Linkage", "aftermarket" intake, "8 yr old" tanabe lowering springs
EnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problemEnJoiThaRex has a Rep problem
mixing is bad like stated
if you use different widths thats fine which many ppl do but other than that its not reccommended
for safety reasons (screws up the whole alignment setup, among other things)
EnJoiThaRex is offline
Old 04-26-2008, 08:36 PM   #9 (permalink)
I don't do any racing, drifting or anything crazy like that. When I said mix tires, I mean mixing brand or having different thread design. Of course the size is still the same. As I stated before the tires that I need, they no longer make.
Old 04-27-2008, 07:58 AM   #10 (permalink)
Dark Samurai
BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?
Unless you're seriously "pushing" the car, I don't see it.
As a poor teenager, my Cutlass 350 S had different tires
on all four corners. And that's a heavy car.
EDIT: RETREADS, no less!
BlueBallz is online now
Old 04-28-2008, 03:42 PM   #11 (permalink)
Dark Wind
iLLeFFeKt CiViC's Avatar
Car: 93 civic dx
Put the tires with better tread in the front and the worn out ones in the back.
That should hold you over until you save money for a set of 4 new tires.
1991 Galant VR-4
1989 Camry -daily beater
1993 Civic dx-sold
1991 Eclipse gsx-sold
iLLeFFeKt CiViC is offline
