Light Rims = Better Gas Mileage? - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Go Back   Honda Forum : Honda and Acura Car Forums > Performance - Tech > The Discount Tire Direct Tire, Wheel, Brake & Suspension
Old 03-28-2004, 02:43 AM   #1 (permalink)
SimpleGreen is an unknown quantity at this point
Question Light Rims = Better Gas Mileage?
What's up everyone...it's been a while -
Just like the title says, will putting on some lightweight rims result in better gas mileage over stock? I know for a fact that rolling on heavy rims sucks up mileage. (That's why I'm getting rid of my 21 lb. Monsoons for a set of 13.5 lb. Slipstreams ) PLEASE no smart-a** responses; common sense isn't always correct.
If anyone has personal experience with this, let me know how it's worked out for you. Thanks!
'98 Civic EX
See it here if you want! Pics with 16" GM Slips coming soon!
N/A bolt-ons, cool stereo, exterior stuff...
(damn I want my old sig and posts back!)
SimpleGreen is offline
Old 03-28-2004, 03:11 AM   #2 (permalink)
IntegraXTR's Avatar
Car: E92 M3
personally i saw no difference in mileage on my teg when i opted for my 17" rims..
then again they are 15 lbs each hehe.
air pressure is a better determinate than rim size/weight for mileage imo
IntegraXTR is offline
Old 03-28-2004, 06:17 AM   #3 (permalink)
mike_sho's Avatar
Car: 93 Honda Prelude VTEC
Yeah its kinda funny. Rims can store energy just like the flywheel , so it all really depends. Im guessing the weight savings alone will equal better mpg and speed.
But im not sure if the actual rim being lighter would always cause for better mpg , because at speed the heavier rim wont slow down as much..im not an expert at physics. But im pretty good at working out weird crap like this.
Im thinking if you stop and go a lot , the lighter rim will get better mpg , but if you cruise on the highway the heavier rim just might get better mpg. Im just kinda hypothesising here because with lightweight flywheel and stock flywheel on the same car , if it were to go up a hill , the one with the heavy flywheel , will go up faster , while downhill the lighter one will catch back up and once level they will be at the exact same spot. Im pretty sure thats a good explanation of how flywheels and weight savings on the drivetrain work.
A heavier flywheel can make for a easier launch as it has more engery to push with. While a lightweight flywheel has to be revved up in order to get the same movement going. They basically change how the car works.....as does getting lighter rims.
But another good thing for lightweight rims is they put less weight on the suspension , so there is less weight acting upon them so they can do their job more efficiently. Always a plus....
If there were any I would buy some carbon suspension arms. Them shizzles would own...suspension weight reduction feels like no other.
HARDmotion
mike_sho is offline
Old 03-28-2004, 10:42 AM   #4 (permalink)
Car: 2002 RSXtypeS
Mods: YES
YourUserName is on a distinguished road
If the mileage increases from using lighter rims the amount is going to be measured in 100ths of a mile per gallon. You won't see a significant increase. The best way to optimize mileage would be to make sure your tires are properly inflated.
THEOLDMAN's Radio Show Thursday 10 AM to Noon EST Eclectic Mix of Blues Folk Jazz R&B R&R
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming ............."WOW! What a ride!!!!!"
Saved me! New Liver 30APR04
YourUserName is offline
Old 03-28-2004, 09:47 PM   #5 (permalink)
Super Ban-Finger Mod
UltraMagneticAL's Avatar
Car: 01 MR-St & 08 M3
heh that flywheel lesson looks oddly familiar
if the difference is like 3 lbs/rim, mileage won't be very noticable
however, weight will play a factor in overall performance of the car....size is another factor....larger diameter rims will have a higher gyroscoping effect which will increase straight line stability, but sacrifices better cornering.....so why do you see race cars w/ big rims? to accomodate the HUGE brakes that stop their 400+hp engines.....tire sidewall is important in handling also blah blah....i guess it just depends on what you plan on doing w/ the car...
Natural Progression...
H22A Accord....Turbo MR2.....E92 M3....07 R6s
Nulla tenaci invia est via.
UltraMagneticAL is offline
Old 03-29-2004, 09:49 AM   #6 (permalink)
lOOkatme's Avatar
Car: 99 lude
Mods: too much to list
lOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problem
Lighter rims will have better gas milage around town, and bigger heavier rims should have better milage on the highway.
lighter rims accelerate faster meaning your putting more power down to the wheels....you just made your drivetrain more efficient.
- Mario Andretti
Car for Sale. PM me.
lOOkatme is offline
Old 03-29-2004, 10:30 AM   #7 (permalink)
Ahhh yes....that's another affect of the heavier rims...they have a higher inertia blah
Old 03-29-2004, 12:35 PM   #8 (permalink)
mike_sho's Avatar
I just said that exact same thing in my post
HARDmotion
mike_sho is offline
Old 03-29-2004, 12:37 PM   #9 (permalink)
mike_sho's Avatar
Why does the flywheel lesson look familiar? It came from the top of my head as does most my information. Ive said something similiar to this before in the forums?
HARDmotion
mike_sho is offline
Old 03-29-2004, 12:44 PM   #10 (permalink)
Car: Prelude Type SH 2000
Mods: Momo Shifter
Turbomice2 is a name known to allTurbomice2 is a name known to allTurbomice2 is a name known to allTurbomice2 is a name known to allTurbomice2 is a name known to allTurbomice2 is a name known to all
Without saying the exact words, you just explained angular momentum. A heavier rim or one with a larger diameter has a greater moment of inertia. So if a car has a rim with a greater moment of inertia, it takes a greater force to accelerate at the same rate as a car with rims with lower moment of inertia.
On the other hand, while doing highway driving, the rim with the higher moment of inertia carries greater angular momentum, so forces from the road or wind resistance affect it less than a rim with a lower moment of inertia.
Turbomice2 is offline
Old 03-29-2004, 12:59 PM   #11 (permalink)
Car: 95 civic garaged while i live downtown
Hooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problemHooked_on4 has a Rep problem
What is the best Tire pressure to run, to increase gas milage? im around psi on my 205-40-16's
My Old Ride Here
What if all the worlds inside of your head, just creations of your own. Your devils and your gods, all the living and the dead, and you really are alone.
Hooked_on4 is offline
Old 03-29-2004, 01:18 PM   #12 (permalink)
IntegraXTR's Avatar
Car: E92 M3
you're around what psi on your tires?
Old 03-29-2004, 01:48 PM   #13 (permalink)
pp10
http://www.superhonda.com/forum/showthread.php?t=146500
Old 03-29-2004, 01:59 PM   #14 (permalink)
Car: 2002 RSXtypeS
Mods: YES
Whatever the manufacturer specs are for your car, which is on a sticker in the doorjamb. Your tire pressure should remain the same whether you have 195/65/14 or 205/40/16 tires. If you overinflate your tires to make them roll easier you will wear down the center of the tire, if you underinflate you wear down the edges. If you are tracking your car you may want to change pressures to suit your needs at the track.
Old 03-29-2004, 02:08 PM   #15 (permalink)
whoops, I ment 30 psi
And YourUserName its the same as OEM Spec???
My Old Ride Here
