Old 03-29-2004, 08:49 PM   #1 (permalink)
Car: 97 accord
azian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problemazian21485 has a Rep problem
lower rear struts braces the same as tie bars?
the guy selling these called them strut braces..just making sure they're lower tie bars cus that's wat they look like? am i right?
azian21485 is offline
Old 03-29-2004, 09:25 PM   #2 (permalink)
lOOkatme's Avatar
Car: 99 lude
Mods: too much to list
lOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problemlOOkatme has a Rep problem
top one is a strut bar, or upper tie bar.
the lower piece in the picture is a lower tie bar.
- Mario Andretti
Car for Sale. PM me.
lOOkatme is offline
Old 03-30-2004, 10:29 AM   #3 (permalink)
Car: 1998 CW ITR
Mods: STOCK
SERPENT is an unknown quantity at this point
Jdm or Usdm?
Hi, I am a new member and this is exactly what I am looking for.
Can you please provide me with part numbers?
Are they JDM?
Is it worth buying these upgrades in Japan or US (If available)?
I know someone who's going to Japan.
Thanks.
SERPENT is offline
Old 03-30-2004, 11:11 AM   #4 (permalink)
Car: 97 accord
Are they JDM?
Thanks.
dunno the part numbers..its coming from a private seller
no their not jdm..their generic bars for $15 dollars =)
Old 03-30-2004, 11:50 AM   #5 (permalink)
Car: 1998 CW ITR
Mods: STOCK
Thanks for the info you are providing me today. In the recent posts and prior to the reconstruction of this site, I have seen pictures of the rear tower brace very very similar to the OEM ITR front strut tower brace (if I said it correctly?) with a small Type R sticker on it too on one side . People in this board were also claiming that it is an OEM part. I am not sure if it is true that the rear tower brace was only made available in Japan and Canada back in the day when ITRs first hit the United States and you have to special order them from Japan.
I only say what I have read and seen in this site.
Thanks in advance...
SERPENT is offline
Old 03-31-2004, 02:23 PM   #6 (permalink)
Super Moderator
Shiba-Kun's Avatar
Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?Shiba-Kun you're still here?
Are they JDM?
Thanks.
Yeah, those are "eBay specials". Check there and you'll find more of them then you can shake a stick at.
http://www.fullclipusa.com/store/
SHO Premium Member #1.
Shiba-Kun is online now
Old 04-01-2004, 10:12 AM   #7 (permalink)
Car: 1998 CW ITR
Mods: STOCK
By far, you are the greatest!
But are these really JDM made upgrades?
Thanks in advance!
SERPENT is offline
Old 04-01-2004, 02:40 PM   #8 (permalink)
Car: 93 Accord Coupe
uncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to all
Thanks in advance!
it's wkdm
who knows. on ebay, you must take everything with a grain of salt.
there was no mention of them being u.s. or japan made in the initial post, so your guess is as good as mine.
as far as trying to get an upgrade on a strut tower brace and/or lower tie bar, you can't just use any old part. you must use one designed for your car. as i have no idea what type of car you have, i'm not sure how much we can help you in this thread.
uncle_el is offline
Old 04-01-2004, 06:37 PM   #9 (permalink)
Car: 97 accord
don't worry so much on JDM made upgrades...
Old 04-07-2004, 07:27 AM   #10 (permalink)
Car: '93 Del Sol S
Mods: ask if you need to know
Phantom_Sol will become famous soon enough
only worry about them if their name begins with:
carbing
cusco
or tanabe
lol
SERPENT you are probably the most polite person on this board. Everything is so formal.
anyways:
bars help stiffen the chassis. the end. there are some that work better than others but as always it all depends on how much money you are willing to spend. then eventually cost to gain is unequal and it becomes redundant. but as far as affordability goes (affordability used loosely)
i lov emy neuspeed upper strut bar... (even though it doesnt bolt onto the strut section) very stiff and for 100 affordable
lower tie bars vary. some liek solid some like threaded. i personally use solid bars because there isnt much you can do to preload a subframe. i have a cusco.
should you get a strut bar or tie bar that has threads, remember to mount them loose then rotate the bar so the threads push the mounts outward. you dont need to wrench on the bar but give it a good guestimated 10 lb of torque. this applies pressure to the frame and subframe and makes it slightly stiffer.
Dont take life too seriously, no one gets out alive.
The replacement for displacement is technology
NOSVTEC; hope youre kickin back watchin over us...R.I.P
now with 273 AWHP
^my GIRLFRIEND driving my car at the autoX
Phantom_Sol is offline
