Pedal Play
Recently I had a reptured brake line on my Accord, after diagnosing the problem I ordered a new set of Stainless Steel Brake Lines. Along the course of changing out all the factory lines I had to replace one of the lines running from the ABS Module to the Caliper due to a stripped nut. After bleeding the brakes I've noticed that there still is about an inch and a half of pedal play before the brakes feel as if they're being engaged. As of right now there are no other visible leaks within the system and I have not seen any fluids that are leaking out. What reccomendations do you guys have and is there anything else that could possibly be wrong with the car ? Thanks much
-Aj
