What type of wheels are they? Aluminum?
If they are aluminum they are easy to fix. First, there is no way to fix the edge of the clear coat vs the rest of the wheel. You need to sand your rims. Not only will sanding remove the entire clear coat, but it will remove the nicks and gashes when the wheels were curbed.
All you have to do is wet sand the dish and lip with many different grits of paper. Wet sand in this order, 150, 220, 400, 600, 800/1000 + grit. Once you are finished take some "neverdull" and polish the entire area that you sanded. Then if you want, you could have them clear coated - but there really is no need.
It takes me about 3 hours of wet sanding for each 17" wheel, but I make sure I get every nick and ding out.
Your only investment is time, sandpaper and "neverdull." That should run around $10 to $15 -
Oh you could wet sand them while they are on your car, but I find it easier to lay them horizontally and stack them up because it allows a better grip on the sand paper.
