Skunk 2 LCA Increase Ride Height
Hey guys I’m new to the forum, I’m restoring an old 93 Del Sol si and I noticed something worth mentioning.
It seems there are variations in the shock mount height of 3 LCA’s that I have in my garage. Ill explain:
When I put the Skunk 2 LCA’s on top of my factory LCA’s both outer holes align, however, the shock hole doesn’t. The Skunk 2 shock hole is slightly higher ( about ½”). It appears to be along the same vertical axis, but the horizontal is definitely off, not concentric at all.
I also had a lone passenger side LCA out of an Acura Integra DC kicken around and I noticed the same thing except this time the Skunk 2 LCA hole was off by much more, maybe closer to an entire inch
Assuming I’m not crazy wouldn’t that actually raise the rear end?
The part number is 542-05-0100
Any input would be great
