i did this swap on my car, the motor droped right in, New motor mounts were needed because the bushings were beat. You have to get a integra header if it going in a civic because of the header clearence. So dont go try'n to throw on a B16 header cuz it will hit your oil pan. When doing any swap make sure to inspect you motor, i.e injectors,crank pulley, clutch, ext when its out of the car, so it make yor life easier.
