Originally posted by Girl
Wouldn't you get a lot more power from boosting a CRVtec then just a normal B20?
If you get your cams profiled to the equivalent of the DOHC VTEC head (when VTEC is engaged), & considering flow rates through the head are the same, then it will make no more power. If you can get your B20 to rev out to 8000rpm, have the head flowed to the specs of a DOHC VTEC head & get the right cams to run at that speed, then theoretically, a DOHC VTEC will make no more power than the non VTEC B20. Just remember, the DOHC VTEC fitted B20 will be more tractable at low rpm compared to a high rpm high lift & duration cam fitted non VTEC B20. DOHC VTEC gives you two cam profiles for low & high rpm, whereas a non DOHC VTEC only has one cam for the entire rpm range.
But seeing as you are looking at forced induction, you do not need wild profile cams to make good power & torque (generally, the more lift & duration the cams have, the more power, but low rpm torque & response is compromised). Just to compare, a naturally aspirated 996 Carrera 3.6 has more aggressive camshaft profiles as the 996 Turbo 3.6.
Overall, the average B20 with DOHC VTEC head will make more power than a standard B20 (because most people don't really port the head to DOHC VTEC specs, etc.). The extra money you will spend on putting a DOHC VTEC head, you will be better off porting the standard head, getting proper profiled camshafts, & raising the boost slightly to make the extra power. You really don't need the extra revs when you are adding a turbo (the turbo fills in this gap).
I hope my post is legible.
