Old 05-28-2002, 10:10 PM   #1 (permalink)
Car: what car??
Mods: modifications..hrm..
B20 within a B18?
my original plan was to put a B20 in my civic, but it is illegal in california to do so since they are not in the same class. what if i put the B20's pistons and rods in a B18B2 engine?(non-vtec) will i get a 2.0 displacement or would i still get 1.8?
GSteg is offline
Old 05-28-2002, 10:25 PM   #2 (permalink)
jldao is an unknown quantity at this point
I thought California's law stated that you can put anything in as long as it's the same or newer year of the car which has nothing to do with "class"? For example if your car is 1999 model year, you can put an engine that's 1999 or newer. I could be wrong, ask a tune shop near you or better yet, flag down a cop and ask him.
jldao is offline
Old 05-28-2002, 10:29 PM   #3 (permalink)
Car: what car??
there are 3 basic rules...
1. must be in the same class. GWVR must be within a range.
2. the engine is suppose to be the same year as the car or newer
3. the engine must come from a low emission vehicle.
i don't quality because fo rule 1
GSteg is offline
Old 05-28-2002, 11:39 PM   #4 (permalink)
Car: 89 CRX Si
Mods: springs/shocks, K&N airfilter, Brembo Rotors, Earls braided lines, Axxis Pads...
XPystchrisX is an unknown quantity at this point
b20 pistons are too big to put into a b18 block. however if you use the ls intake manifold and header i believe the b20 block is basically identical to the b18 block as long as the tech doesn't check the engine code.
89 CRX Si Y-49
The crx is fixed and there's extra money in the bank... now the modifications start... oh yes... now is the time...
"Team Duct Tape"
- Duct Tape is like the force... there's a light side, a dark side and it holds the universe together. -
Member 002
XPystchrisX is offline
Old 05-29-2002, 06:16 AM   #5 (permalink)
Car: what car??
so can i bore it out to 2.0? if so, how? i don't want to stroke it. just want to bore it like honda did
GSteg is offline
Old 05-29-2002, 06:18 AM   #6 (permalink)
Car: what car??
i haven't thought of this until now, but what if i change the engine code on the block to from B20Z to B18B2?..if all goes perfectly..it shouldn't be a problem right?:
GSteg is offline
Old 05-29-2002, 01:35 PM   #7 (permalink)
Car: CiViC98
Mods: not enough
B20BbenN is an unknown quantity at this point
If you have the money, put new sleeve in the B18B (GE sleeve..84mm) and put 84mm piston in it!
The stock sleeve will not last long if you oversize them to 84mm.
and.....it's B18B1 not B18B2.......
B20BbenN is offline
Old 05-29-2002, 02:56 PM   #8 (permalink)
Car: what car??
it's a B18B1? the last time i checked, my uncle's 97 integra GS has a B18B2 in it. am i seeing things?
so wait..how would i bore it out to 2.0 again?
GSteg is offline
Old 05-29-2002, 03:54 PM   #9 (permalink)
Car: Produce Clerk
MikeKid is an unknown quantity at this point
Originally posted by GSteg
i haven't thought of this until now, but what i if i change the engine on the block to from B20Z to B18B2?..if all goes perfectly..it shouldn't be a problem right?:
there's serial codes too...
MikeKid is offline
Old 05-29-2002, 04:02 PM   #10 (permalink)
Car: what car??
[quote]Originally posted by MikeKid
[/QUOTE
what if i changed the number to a b18's serial code? i can use my uncle's serial code. is it on like a sticker or a metal plate?
GSteg is offline
Old 05-30-2002, 01:56 AM   #11 (permalink)
Car: got one
turbob20ek is an unknown quantity at this point
lol screw that california law i dont know a smog guy that checks the stamp on your block as long as it passes smog visually and on the sniffer i dont see what you are worried about the average smog guy has no idea what a b20 or b18 is or do they car as long as it says honda has all smog shit and passes you'll be fine man
Team No Limit
96 Championship white HB
b20/vtec turbo
300.8 hp/211 tq @7 psi all stock
12.60@112 daily driver
just converted to 99 front end and built a bulit proff b20 will have new hp numbers and track times after i break in the beast
turbob20ek is offline
Old 05-30-2002, 02:16 AM   #12 (permalink)
Car: 94 CX EG6
Mods: JDM
Roger is an unknown quantity at this point
Just drop the B20B in. TurboB20EK is right. If the car passes smog with all of your smog attachments attached, then you souldn't even worry about it. Check this out, I gotten pulled over by a cop in my city and he told me to pop the hood, I said, " Damn, I'm jacked because of my turbo system in my civic." He looked at my car and said, "what is that in your car, an intake system ??" I said, yeah, its new, just came out. The cop was so dumb, I should've said, " no sir, that my new air conditioning unit. " Anyways, If I were you, I wouldn't even think about boring out a B18 series motor. Your just wasting time and money. Do me a favor and drop the thing in.
Roger is offline
Old 05-30-2002, 06:19 AM   #13 (permalink)
Car: what car??
but don't i have to register the engine? oh well..i'll just give it to my uncle to smog check it.
GSteg is offline
Old 05-30-2002, 09:52 AM   #14 (permalink)
Car: 2006 Honda Accord EX V6
Mods: 2006 Honda Accord EX V6 Sedan/ 30k miles/ 4 Sale! $18,499
Hybrid Fever is a name known to allHybrid Fever is a name known to allHybrid Fever is a name known to allHybrid Fever is a name known to allHybrid Fever is a name known to allHybrid Fever is a name known to all
When you say "visually", what exactly do you mean? Like what do they look for on visual? If I were to put a JDM GSR motor in a 95 civic hatchback would I just tell em that it's the stock motor? What visual things will they look for on the motor? Do you have to add anything to a JDM motor to make it look like a USDM motor?
Hybrid Fever is offline
Old 05-30-2002, 11:53 AM   #15 (permalink)
Car: got one
what are you tryin to do take it to the dmv and get it to pass some kind of inspection, the only thing i know of is if you see the ref. and then i dont thin a ls vtec would pass but you should search for some one who has one i think your reading to far into it you will be ok as long as your car passes smog bro. and if you uncle can do it you got i made , there is no need for a dmv inpection there is tons of hybrids lke my self roaming the Cali streetz .... goodluck bro, if your uncle is smogging your car then no big deal he prob dont even car about the visual..
Team No Limit
b20/vtec turbo
