Old 03-19-2002, 11:15 AM   #1 (permalink)
Car: 97 GSR Sedan
IslandBoy is on a distinguished road
Question B20Vtec concept....
Can you break it down for a dummy on how this works?
What parts are needed? Is this set-up usually for FI or NA? Can this setup fit in a civic,integra,prelude, without cutting anything?
I already went to the crvtec site....any other sites?
Who knows it...
Feels it...
-Bob Marley-
IslandBoy is offline
Old 03-19-2002, 10:38 PM   #2 (permalink)
Car: 1994 Honda Civic CX
Beyond Imaginat is an unknown quantity at this point
I'm not sure if this site has what you're looking for but you can get nicely built CRV/VTEC's from them ...
www.importbuilder.com
Beyond Imagiantion
'94 Honda Civic CX
*JDM Whore*
Beyond Imaginat is offline
Old 03-19-2002, 10:47 PM   #3 (permalink)
Car: got one
turbob20ek is an unknown quantity at this point
crv vtec
the b20 block is the same as an ls only it had a 84mm bore rather then a 81mm like that ls the sleaves are also stronger, you may already know that , but the 2.0 block mated to a vtec head is a very potent combination, the only problem is that the bottom end is not ment for high reving so if you looking for a hight reving motor you might want to consider building it repalcing the stock rod bolts will help a lot ARP makes great rod bolts.....
the motor bolts right into any civic or integ that can fit a b16 , it uses the same tranny as any other b series...ect... you need to run a oil line from the back of the block.to the head . just like ls vtec and you need to seal up the oil feed on the head adn re locate the dowl pins on either the head or the block your choice...
i love my b20 couldnt be happier , but i am building one in june need more boost ...lol hope i helped a lil ...ohh also like it says in the crvtec.com site you need to machine the stock pistons for vtec valve clearance if you are using stock pistons i have seen over 200hp na. and my 300hp @ 7 psi all stock is another example
Team No Limit
96 Championship white HB
b20/vtec turbo
300.8 hp/211 tq @7 psi all stock
12.60@112 daily driver
just converted to 99 front end and built a bulit proff b20 will have new hp numbers and track times after i break in the beast
turbob20ek is offline
Old 03-20-2002, 08:36 AM   #4 (permalink)
Car: 97 GSR Sedan
Talking Thanks for the info guys.
Who knows it...
Feels it...
-Bob Marley-
Old 03-20-2002, 11:31 PM   #5 (permalink)
Mercutio119 is an unknown quantity at this point
i thought that the b20/vtec was suppose to have alot of torque...
Mercutio119 is offline
Old 03-21-2002, 11:04 AM   #6 (permalink)
eagle1 is an unknown quantity at this point
turbob20ek i would like to know what kind of turbo your using because im thinking about building a crvtec or a ls/vtec turbo but i need 2 talk 2 you about the parts and tuning so i was wondering if u can e-mail me so u can explain somethings 2 me thanx my friends that u can get me at is ardoch@aol.com
eagle1 is offline
Old 03-23-2002, 06:57 AM   #7 (permalink)
Dark Samurai
LudeAction is on a distinguished road
Originally posted by turbob20ek
crv vtec
nice setup bro, what do you run, id guess low 12's???
LudeAction is offline
Old 03-23-2002, 01:10 PM   #8 (permalink)
Car: 1999 Eclipse GS-T Silver
Mods: Personal best of 12.93 at 111mph on radials generally low 13's tho and should pull mid 12's on slicks.
Low Flying GS-T is an unknown quantity at this point
NO it takes more than just power to turni n a low 12 sec time slip on an FWD. my guess would be low 13's to high 12's on street tires and maybe low 12's with slick, LSD, and a good suspension. Once I finish my port work and Fuel I will be putting down close to 320WHP and about 350lbs of TQ but will most likely not see lower than high 12 sec timeslips due to traction issues.
Formaly "H2O" from PH.com an formally owned a 92 Accord EX I/E and 17's and 95 Accord EX coupe I/H/E full ignition and VAFC with too many other mods to lists
99' Eclipse GS-T
Forced Performance Big T-28 turbo ported, ported exhaust manifold, ported O2 sensor housing, RevHard Big Front mount Intercooler (polished), Intake filter kit, 2.5 inch turbo inlet pipe, N1 3 inch exhaust system, 2.5 inch downpipe, Greddy profec B boost controller set at only 15psi, Greddy type S Blow off vavle, Greddy upper Intercooler pipe, 3000GT VR4 fuel pump, Accel sparkplug wires, Greddy turbo timer, Pocket logger and Palm m105 for scanning. Big System three 12's, DVD, TV, big amps yada yada!!!
Low Flying GS-T is offline
Old 03-23-2002, 03:32 PM   #9 (permalink)
Car: Honda CR-X Si
Mods: a few things here n' there....
DAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/GoddessDAFeLUNG Rep God/Goddess
turbob20ek what kind of set up are you using for you turbo? Intercooler...what size turbo etc. Ever think you'll run close to 1 bar of boost?
2002 S2000
90 CR-X Si
158.1 hp 112.0 tq (with i/h/e) (lost its life in a horrible accident...rest in peace)
Gone...but not forgotten...
I'm not even going ot beat around the bush with this. 50% of the people on this board dont know their asses from a hole in the ground and it pisses me off sometimes..
DAFeLUNG is offline
Old 03-24-2002, 04:05 AM   #10 (permalink)
Dark Samurai
well, I would guess if you got the lsd, slicks, traction bars, and a 2-step launch controll..low, LOW 12's shouldnt be to hard.. is the car gutted or a daily driver?
Old 03-26-2002, 08:46 PM   #11 (permalink)
Car: got one
i am running a .54 trim turbonetics to4e turbo with a greddy intercooler, i ran a 12.80 recently but am looing to get more track time to get used to the car and get it down to the low 12'z just need practice iff you need and help hit me up with a private message and i will get back at you asap
Team No Limit
b20/vtec turbo
