ok, my JDM B16 was just rebuilt. and with only 453 miles on it....spun a rod bearing we pulled it apart and the only way i can explain it is FUBAR! the guy that rebuilt my motor is paying for a new motor. i've just bought a zex wet kit that i was going to put on the 16 after i put a few thousand miles on it but now i'm thinking B20B. but my tranny is of course a B16. so now on to my question....how will the gearing of my B16 tranny match up, and since the compression of the 20 is low, a 100 shot should be no problem right? or do i need to do diffrent pistons and maybe up the compression... my head off my 16 is now garbage intake manifold i'll keep, and oh yes i want the B20/VTEC. but i have a friend that says i don't realy have to do a VTEC conversion to pull a ton of power out of the B20........if you guys were in my shoes ( and i wouldn't wish this on my worst enemy ) what set ups would you run?
my car isn't designed to be an all out race car. just like to have something to play with the best of them. talk to me fellas, am i on the right track?
93' Dx coupe: MOTOR B20B/ GSR, Crower 404-2 stage 3 cams, heads been remilled and port & polished, 5 angle valve job, ARP headstuds, DC Sport 4-1, Magnaflow hi-flow cat, Magnaflow mandrel bent cat back, Gear Speed carbon coated syncros, clutch masters stage II clutch, Zex 75 shot wet, Unorthodox crank pulley, Venom fuel pump, RC310cc injectors, P28 tunned w/ Crome Pro.
ICE JVC Double Din, (in lower JDM console) Rockford Fosgate Power Series 800/4, MB Quart Qs 6.5" , 12" fosgate P3 shallow mount flushed in the floor of the trunk, 1 Farrad digital Monster Cable cap, all JL wiring, fully dynomatd (firewall back), Kenetic deep cycle battery
thanks gurusan.....at least one person has given me feed back
i'm gonna run a 75 shot. i'm ordering the B20 from H-Motors next Thursday. i've already got a GSR head lined up. just need to get the eagle LS/VTEC conversion kit and it's on like donkey kong. i've got crome-pro so retuning my ecu is no problem. we're guestimating an easy 12 sec. set up. where my B16 on the bottle i was only hoping for maybe high 13's......everything happens for a reason.... ....
yes we're building the bottom end. i've got Angelo from HolySmokeRacing building it this time. he's been building honda race engines for SCCA since the 70's. he is "the" honda guru of my area. so the rod bearings should be fine this time that was the most expensive mistake of my life. i don't know what happened cause i wasn't dawging it.......but now i'm pummped about this B20 swap. i'm not going to be able to do the CR/VTEC swap immediatley. but we are doing pistons/rods etc. off the top.
the short gearing of the b16 tranny could be an issue for you. You may want to investigate that a little more. power doesn't matter if you can't get the tires to hook up.
i was told that as long as i'm not doing a blower or turbo that my tranny will do just fine. cause i'm basicly keeping it N/A except for the jug. but they said if i decide to boost it i need to get a LS tranny.
