d16y8 >>> b16
Hi guys, I have a question and it's loaded.
I have a 2000 HX that WAS auto and well the engine threw a rod, not to mention the fact that the wiring harness is junk on the engine. I decided to just do a auto to manual swap and I'm about done I think. It's a OBD1 B16 with a P30.
I installed the engine and tranny and all necessary hardware. Pedals, linkage, shifter and jumped the neutral safety switch. Now the big question. Can I use the P30 or do I need a chipped P28 to make this work best?
Course I'll do the OBD2(?)-OBD1 conversion harness from rywire, boomslang or phearable whatever. But what harness should I use?
I tried using a 99 Si harness and ECU but of course it doesn't want to work. I even got the conversion harness for OBD2b>OBD1 and it still doesn't start.
All help is appreciated.
