Mods: swap engine from D16 to B18 and some other stuff (still working on it)
Help!!! DX 2000 to B18c1 swap
Hey what up people!!! I'm new to the site and i would appreciate any help u can give me. I have a Honda civic dx(d16y7) series and i bought a B18c1 engine to do a swap. now... if somebody could give me an exact list off extra parts i need to get i would appreciate it, and is it gona be a problem converting from obd1 to obd2?
well im kinda tired but i can name some parts shift linkage,ecu,axels,mounts,and obd converter(will not pass inspection)im not sure about the harness going from ob1to 2
92 si swapped vx hatch(my self)my new baby
what all came with the swap when you bought it? That will help us steer you in the right direction as to what you need. Converting from obd1 > obd2 wont be a problem if you have an obd2 ecu and all the needed sensors, which if the motor has it, youre set, but we need to know what all you have
I just have the motor and tranny all the rest parts i still need to buy. The problem is i don't know what parts exactly couse from everybody i hear different story's thats why im asking u guys.
hey i have the same motor in my 96 civic dx. the main thing you need to do is take the gsr wiring harness and the dx wireing harness and mate them together, so that the dx harness has the v-tech wireing. make sure you have all your sensors for the motor. the other thing you're going to need is on the driver side motor mount you will need an adapter to mount the gsr in the car, also the rear mount you will need a new one. i got all new mounts from hassport.com, i upgraded to the racing mounts. you can use the shift linkage from the civic, and you will need gsr axles, try to find a p72 ecu if you dont already have one. that should be about it, let me know if i left anything out.
This should be in the B series section. They would be of more HELP. This has also been covered in that section COUNTLESS times. Use the SEARCH FUNCTION - it will pull up STACKS of info. Good luck with your swap though.
HENRY
