Old 08-07-2002, 08:37 PM   #1 (permalink)
Car: 95 Acura Integra
blase is an unknown quantity at this point
hybrid integra
I'm swapping a b16a engine into my 95 integra LS, and I'm trying to figure out which tranny I can put in it, while using my stock axles. I need something high rev. Also, anyone know what separates a type-r tranny from a GSR or B16 tranny? (other than the LSD?)
Thanks,
Blase
blase is offline
Old 08-12-2002, 11:10 AM   #2 (permalink)
Car: 97 Teg
dmcintegra is an unknown quantity at this point
why do you want to put a 1.6 engine in there, you could just put the B16 head on your ls block, puts out GSR numbers. OR you can get a GSR motor which goes to 8100 rpm and more about 8500 safely.
Type R and B16 trannys have closer gear ratios which mean they are quicker than the GSR tranny.
dmcintegra is offline
Old 08-12-2002, 02:47 PM   #3 (permalink)
Well, actually it's a 1.9L b16. (Bored and sleeved to 85mm.) It redlines at 11.
To refine my question, is there some sort of quality difference between the type R tranny and a b16 tranny? Why is the TypeR so much more expensive and sought after?
blase is offline
Old 08-12-2002, 09:01 PM   #4 (permalink)
Mods: 4door Teg- 13.8 ls/vtec
Re: hybrid integra
Thanks,
Blase
Keep in mind all B-series trannys are interchangeable with any B-series engines.
Here is a website with all the gear ratios/tranny names. You can check out the differences yourself.
http://www.bseries.net/html/specs/btrannyspecs.php
It depends on the setup that you want to go with, for turbo id go with the LS(S80/Y80) tranny because of its longer gears, and for N/A applications a tranny with short gear ratios will aid you to reach those high rpms ie; b18c5/b16/b18c1 trannys
______________________
94' integra sedan SOLD
03' Yamaha R1 ltd. Ed.
02' BMW 330 Ci
02' Suzuki GsxR
JAYMAN320 is offline
Old 08-15-2002, 09:35 AM   #5 (permalink)
GunMetal Member
absolutmugen is an unknown quantity at this point
try and snag a JDM b16 or b18c1 because they're LSD equipped
A.K.A. civicsifanatic
If it ain't Ford, it AIN'T
JDMitis - a severe immunological disorder uncurable with modern medicine; resulting in obscene amounts of money being spent on factory japanese parts that only others who had increased susceptibility to this opportunistic infection can notice the differences.
absolutmugen is offline
Old 08-15-2002, 11:14 AM   #6 (permalink)
agent_noman is an unknown quantity at this point
From what I read on another post...
Aside from the LSD, the Type R tranny is supposedly stronger than the S4 (b16 tranny). It has a larger bell and is beefier.
Keep in mind your application. If your main concern is racing then by all means go for the shorter gear ratios. But if your on the freeway quite a bit your might want to really consider the GSR tranny because it starts to get annoying when your cruising in 5th at 80 mph and your tach reads 4500 rpm.
Old Skool Member back to sell some stuff:
RAZO Competition adjustable heel/toe pedal set (manual)
Hawk HP Plus front brake pads (Civic 96-00)
Headlight Eyelids Black (96-00)
agent_noman is offline
Old 08-18-2002, 07:10 PM   #7 (permalink)
H22YBRID is an unknown quantity at this point
no the prelude type S motor is engine code H22ASSFUCKER and has about 2,220 hp @ 19,000 RPMS.
Shhhhhhhhhhh! its sleeping
H22YBRID is offline
