i have 88 crx si .. i want to put in a b18a1 from 92 integra ...i have motor,tranny,ecu,engine harness,axels,front hubs. is there anything else i need other than mounts and shift linkage? if so any info would be really helpfull.i am also looking for a swap guide thanks for ur help
Welcome to the forum! First off, great swap for the CRX, but you don't need someof those things you have. Motor, tranny, ECU and axles, you're on the right track but as far as the wiring harness, you will use the one from off of your Si. Also, seeing how your car is OBD-0, you will need a distributor, and injectors from a 90-91 integra (or you can use the injectors from the sohc motor anduse them on the B18A1. Also, you need to get a throttle cable and clutch cable from a 90-93 integra. The shift linkage will have to be a custom joint from hasport or something like that. Good luck!
Originally Posted by 9400rpms
hey guys sorry to drop in like this but how do you take out the axles on a honda civic eg 3 dx. the bottom bolt is stuck and jsut keeps twisting forever i think its stripped. is there any other way to get around. thanks and sorry
The bottom bolt of what? There are no bolts on an axle, just the axle nut itself.
im guessing hes talking about castle nut on spindle? also to REXEDOUT if you get the linkage that you need to be modified you can send it to me and i can cut/weld for you for cheaper than hasport
