Ok I for one am getting tired of people asking how they can get engine x in car y. So I figured I would through together this little article. Feel free to add anything you want.
For starters if you have enough money any swap is possible. For instance: YES you can put a S2k engine in a Civic.... but it would be extremley expensive. For that matter you could fit any engine into any car with enough money. So this article is mainly going to outline engine swaps within the Honda/Acura family...
Civics/Integra: The basic rule of thumb for Civic/teg swaps is: All d-series & b-series engines fit into all 88+ Civics without any special mounting kit. Some swaps require master cylinder relocation but as far as motor mounts everything lines right up.
H22a into Civic/teg:
-Can it be done? Yes.
-What are the disadvantages? If you have stock suspension this swap isnt reccomended. The h22a is about 140lbs heavier than your stock engine, so stock suspension probally wont do. Unless of course you enjoy understeer!
-What do I need to fit the h22a into my civic/teg? You need an aftermarket mounting kit from a company like hasport(hasport.com). This basically re-locates your motor mounts so the h22a can fit.
-Can I keep my a/c and p/s? Not very easily. Again there are kits that allow you to keep your a/c and p/s but without these your basically screwed(unless you want to fabricate your own kit).
-Can I still autocross w/ an h22a motor in my civic/teg? Of course but it wont handle as it would if you had a b/d series engine. This unless you invest in a full-coilover kit or some extremly nice suspension.
-What about axles? If you plan on drag racing constantly w/ the h22a in your civic you better plan on buying some beffy axles. Raxle(raxle.com) makes some of the best aftermarket axles, driveshaftshop(.com) is also a good source for aftermarket axles. If you dont want to invest in aftermarket axles 90-93 integra axles will work.
F-series engines into Civics/tegs:
-Can I fit a f-series engine into my civ/teg? Yes. You need to buy the kit for mounting a h series into civics/integras.
-What are the advantages? I cant really think of any.
-What are the disadvantages? MAY throw off wieght dist. a LITTLE but nothing major.
I will update this thread when I have more time... Feel free to help me out by contributing!
